Ems Locking hub kit on a 2007 DRW
Old Aug 29, 2007 | 05:09 AM
Mark Hodowanec's Avatar
Originally Posted by levigarrett76
I just got through installing the EMS kit that eliminates the unit bearings on my dually...Went smoothly, took 5 hours including a dinner and a few beer breaks
I was impressed everything needed came with the kit other than bearing grease and tools
I really liked how the Lockout ended up being flush with my lugnut cover!! I used the 4" holesaw i bought for my b&W Hitch
I will report back later on how i like it mileage etc...I Hand calc every tank so time will tell if there is a noticeable improvement in mileage. I already love the 2wd low...its like the fords i have always been used to!
http://i203.photobucket.com/albums/a...l/P8280009.jpg
http://i203.photobucket.com/albums/a...l/P8280008.jpg
http://i203.photobucket.com/albums/a...l/P8280007.jpg
http://i203.photobucket.com/albums/a...l/P8280006.jpg
http://i203.photobucket.com/albums/a...l/P8270005.jpg
http://i203.photobucket.com/albums/a...l/P8270004.jpg
http://i203.photobucket.com/albums/a...l/P8270003.jpg
http://i203.photobucket.com/albums/a...l/P8270002.jpg
http://i203.photobucket.com/albums/a...l/P8270001.jpg
I thought i would post some pics because i have never found any of this kit installed on a DRW
How much was the kit?
Old Aug 29, 2007 | 06:03 AM
levigarrett76's Avatar
it cost me a little over 1800 bucks shipped to my door with the chromo 35 spline stubs...
It only took me 5 hours because i guess i have gotten alot of experience working on one ton front axles due to my rock crawling hobby
Old Aug 30, 2007 | 05:23 PM
filled up yesterday after my usual mixed city highway driving and got 17.1 mpg, thats within my usual 16.5-17.5 range....3/4 of that tank was with the lckouts installed
Ran 250 miles today pulling 7500-12000 lbs and got 10.3mpg
ill be installing my gear vendors next week hopefully
Old Sep 1, 2007 | 01:42 PM
DiEseLjunKy's Avatar
Give it a few tankfuls I'm sure you'll see a minimum 1.5 mpg improvement I got 2mpg out of mine and think it's the best mod on my truck. I'm also running a gear vendors unit and pleased with that one too. Last night I filled up and did a hand calc at 20.082 mpg which is the first time I've ever cracked 20+. That's normal driving without babying it to get good mileage with plenty of 75/80 mph interstate cruising in the mix. My truck just went over 10K miles and has never been worked hard so it's not really broken in yet. I've seen other guys with these mods doing better, and alledgedly some without, but I'm happy with the numbers because from the dealer lot my truck would do good to get 16 mpg.
Old Sep 1, 2007 | 01:54 PM
I wonder what kind of wheel grease some of you guys with hub kits went with? I'm using Amsoil GRG Series 2000 Syn Racing Grease. I did all my driveline stuff to amsoil and figured I'd give their grease a try just to see. It's a funny looking grease but I like it and will be using it from here on out in the hubs and the U and ball joints too.
Old Sep 1, 2007 | 04:22 PM
CrazyCooter's Avatar
Looks good!
I want to do this with my ride soon.
Does the rotor still just unbolt with the wheel spacer? Or do you have to disturb the bearings and get greasy like the "Oldskool" trucks?
Old Sep 3, 2007 | 08:52 AM
rotor bolts from the backside....so you have to remove the hub like "oldschool"
I havent seen any difference in mpg yet....first tank was 17.1 which is normal....next tank was 10.3, but that was all towing 7-12k, im about to fill up here shortly and it looks like it will be right around 17 as usual
I still love the kit....using 2wd low for backing my gooseneck up my hill was priceless
Old Sep 3, 2007 | 05:12 PM
Got 17.8 today....450 miles of city, highway and interstate combined with about 45 mins total idling
filled up at the same station i always do
It seems this kit has improved my mileage a bit, before i probably would have gotten around 16.5 with all the idling
Old Sep 5, 2007 | 03:51 AM
95ram's Avatar
That kit looks great. I like how it fits the center cap perfect. Looks almost factory. Nice job. I'm planning on doing the EMS kit to my 97.
Old Sep 18, 2007 | 11:18 AM
Ive got a little over 3000 miles on it now, no problems and mileage is up about .8 mpg on average...
unloaded i havent gotten less than 17 since the kit..usually high 17's low 18's...before it was high 16's low 17's
now if i could ever get around to installing my dang gear vendors!
Old Sep 20, 2007 | 06:52 PM
Fisherguy's Avatar
Looks like great idea, the price will mean it's something I'd not likely do though...
Old Sep 20, 2007 | 06:53 PM
i mainly did it for a peice of mind and the 2wd low for backing trailers up hills, its SO nice!
Old Sep 20, 2007 | 07:12 PM
JohnInNH's Avatar
unloaded i haven't gotten less than 17 since the kit..usually high 17's low 18's...before it was high 16's low 17's
Word of caution... Call Gear Vendors and ask them about reverse with their unit installed. Your truck will now have a clutch/friction drive in reverse which can wear out. Post install.
If you have a lot of uphill heavy loaded usage make sure you call GV first to see if the unit will hold up under YOUR requirements.
It's one of the CONS with the Unit.
Smaller U-Joint
frequent oil change & cleaning service
and non direct gear driven reverse. (conical clutch) in reverse
Those are the only CONS I can think of.
FOR ME the PROS are worth it.
Save your tail housing and get a stock drive shaft just in case you loose reverse you could then slap in the old stuff and be on the road till you get it repaired.
I may make up a weather proof PVC pipe container to keep up under the bed for a stock drive shaft and a waterproof 20 mm ammo can for the tail housing..... Just in case I burn out the conical clutch out in the boondocks.
I have no clue just how much torque and wear it will hold up to in reverse.
I have read her where a guy fried his reverse in his GV OD trying to get unstuck in the mud.
Old Sep 21, 2007 | 05:06 PM
thats actually been one of my worries and why i havent installed it yet....
i wont be hauling 24000 pounds anymore....as i now have a 2000 KW t800 tractor with a c12 and eaton 10 spd to pul;l a 40 foot lowboy to move out backhoe and loader....so no more backing that up hills.
I still move 10-15k around pretty regular and im very hesistant....
When i ordered the GV unit they told me i would have no worries in reverse???
Bs i guess
ARGHH
goatbrain5.9
ABDTR #5
22
Mar 22, 2011 05:53 PM
I Stand Alone
Jan 31, 2011 08:59 AM
gdh11
Mar 18, 2008 05:33 PM
Ed Ventura
Feb 23, 2008 07:01 PM
DiEseLjunKy
32
Dec 27, 2007 07:37 AM
