EMERGENCY...8mm bolts
Old Feb 23, 2008 | 11:23 AM
ian515's Avatar
so due to a REALLY STUPID MISTAKE I broke one of the 8mm hold down bolts for the #1 injector. of course all the dealers dont carry them, and I cant find a cummins shop near me. any ideas?!!! I am HOSED
Old Feb 23, 2008 | 11:41 AM
ian515's Avatar
can I just use another 8mm bolt from napa? if I can make sure the threads are the same, maybe throw some lock tite on there?
Old Feb 23, 2008 | 01:13 PM
ian515's Avatar
i matched an 8mm bolt with the one from the engine at napa, gently threaded it in to where the original was, everything seems to work, it torqued to 89inch lbs, and it all seems legit. is there ANYTHING i should be concerned about, or did I just solve my problem?
Old Feb 23, 2008 | 01:16 PM
dozer12216's Avatar
Problem solved if quality bolt.
Old Feb 23, 2008 | 01:23 PM
ian515's Avatar
seems pretty quality. I really dont think I need to be TOO concerned seeing as they are just torqued to 7lbs, so there really wanst much force on these things to begin with right?
Old Feb 23, 2008 | 02:07 PM
vzdude's Avatar
DTR's 'Go to Guy'
It should be fine, even if it is just a grade5 bolt. There isn't a whole lot of torque going on that line, or at least shouldn't be!
Old Feb 23, 2008 | 02:37 PM
rich's Avatar
i've broke em before and used bolts from other places no problems
Txwelder
Feb 6, 2010 02:22 PM
scottsjeeprolet
Apr 9, 2007 09:47 PM
TxDiesel007
Jul 31, 2005 03:04 PM
joemikey
Oct 10, 2002 11:39 PM
