89 INCH pounds
Old Feb 23, 2008 | 09:31 AM
ian515's Avatar
89 INCH pounds
I am installing the injector bolts, and it calls to torque them to 89 inch pounds. I only have a torque wrench that goes to 10 FOOT lbs. and obviously 89 inch pounds equals a little more than 7 foot pounds. can I just tighten them to 10? or will that be too much.
Old Feb 23, 2008 | 09:41 AM
TreeFarm's Avatar
I assume you mean that the LOWEST marking on your torque wrench is 10 lbs. Not knowing what kind of torque wrench you have, or how accurate it is, I would be concerned about how well calibrated it is at the lowest end of its range. That, plus you are talking about a 35% over torque as well.
In your position, I would run out and buy a torque wrench calibrated in inch pounds.
My $0.02.
Old Feb 23, 2008 | 09:43 AM
ian515's Avatar
thats kinda what I was thinking about.
Old Feb 23, 2008 | 09:52 AM
InfernoB's Avatar
Injector installation, proper tools, hummin Cummins.
Priceless!
Sorry if I offended anyone with this, but there is nothing like doing it right. Over and under torquing can cause all kinds of problems. Some people luck out and never have an issue. Is $$$ for repair worth the hassle of wondering if you cracked something or did they seat properly? Probably not.
Old Feb 23, 2008 | 10:40 AM
ian515's Avatar
i totally agree. just bought an inch lbs torque wrench. good to go!
Old Feb 23, 2008 | 10:50 AM
Totallyrad's Avatar
I would have loaned you mine. (but you'd have to pick it up)
Old Feb 23, 2008 | 03:19 PM
supersonictoys's Avatar
napa rents tools
Herrin811
Oct 31, 2009 11:49 AM
502502
Nov 9, 2004 01:35 PM
1Thom
15
Sep 23, 2003 03:05 PM
shaft
Sep 1, 2003 03:37 PM
bdaniel
May 6, 2003 04:43 PM
