EGT temp
Old Jun 12, 2008 | 11:06 PM
  #31
Jim Dynomite's Avatar
When you cool down, is your a/c still running? That will strain the motor at idle enough to delay the cool down. You should be between 300-350 no problem.
What is your elevation? Less air means hotter temps.
Also, I don't see any intake or exhaust mods in your sig. At least get a muffler delete pipe to keep WOT EGTs in check. 1400* for 45 minutes does not sound good.
...........Jim
Old Jun 13, 2008 | 10:10 AM
  #32
nate4567's Avatar
Yea everything is off. And I live at about 6000ft and in about 15 min I can be at around 9500
Old Jun 13, 2008 | 10:37 AM
  #33
HOBrian's Avatar
That is part of the problem... As someone stated before if you add more full to the motor without upgrading your turbo you will get hot temps. Living that high up with less air mass you are doing the same thing. The truck in stock form is adding more fuel but the turbo can't keep up because of the altitude.
Old Jun 13, 2008 | 11:47 AM
  #34
no_6_oh_no's Avatar
Valve body or shift kit
Tourqe converter
billet input shaft.
what else do I need to look at
Unless you are going for 600 hp or better those are the big pieces, IMO.
Upgrade the front band strut to handle the increased pressures better. You could get a lever with better leverage and a heavier band but unless you are going to run obnoxiously high pressures and race/sled pull it really is not needed.
There is a billet cover available for the front accumulator\band apply piston that will enhance the ability to hold higher pressures and it has better seals.
If you do a billet input, there are better sealing rings for the input shaft that come with the Transgo shift kit that will be needed. This is a mandatory update with the increase line pressures. The stock ones will lock in the wrong place and wear prematurely.
You could do a 6 disk direct clutch drum but again unless you are going for big power, the 5 disk holds well if the pressures have been kicked up.
The big hard parts you will need are the input shaft and TC, otherwise its a lot of smaller pieces and just good practices setting up the clearances and such.
Old Jun 13, 2008 | 08:18 PM
  #35
nate4567's Avatar
Can you give me the parts that you would recommend. And where you can get them. I have seen tq converters from 200 - 1300 and input shafts are really expensive, so if I am going to get one I want it to be right
thanks
nathan
Old Jun 14, 2008 | 06:58 PM
  #36
ptgarcia's Avatar
Check out:
Goerend Transmission
HTS Transmissions
DTT
NADP
ATS
Sun Coast
I'm sure I'm missing someone.
Old Jun 14, 2008 | 10:44 PM
  #37
no_6_oh_no's Avatar
thanks
nathan
This is what I did to mine. I have about $2500 into parts including a complete rebuild of trans with new steels and frictions. I did a lot of the work myself so factor in what somebody else is going to want for labor.
Single disk low stall TC, about 1700 stall. I believe its what most call a 10 blade left cut stator. (You choice, but if it was me it would be DTT or Goerends)
Billet 2-3 shift accumulator cover
Billet front band strut
Intelligent Engineering (OPIE) billet input (the smaller one)
Transgo 48RE shift kit
DTT Shift Enhanser
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
Jim in Co
Nov 12, 2003 10:20 AM
turbospl311
Mar 31, 2003 05:09 PM
