EGT install
Old Aug 20, 2004 | 06:41 PM
jk1364's Avatar
EGT install
Ordered Autometer Phantom gauges. I wan't to drop the turbo to drill for the EGT probe is there a gasket between the turbo and manifold? If so where can i get one on a saturday. I am in CA, SF bayarea. More to come later.
Thanks John
Old Aug 20, 2004 | 06:47 PM
Mike67RS's Avatar
There is a gasket but it shouldn't need to be replaced. I just loosened the bolts and dropped the turbo down about a quarter inch. I put a piece of cut cardboard between the turbo and the flange to block anything from dropping. Blow it out with the cardboard in place then tighten it back up after removing the cardboard. This will save you some time vs. removing the turbo completely.
Old Aug 21, 2004 | 12:48 AM
SuperGewl's Avatar
Try NAPA, Cummins, or even your local Dodge dealer that's open on Saturday for the gasket. Just incase you need it
Old Aug 21, 2004 | 12:39 PM
jk1364's Avatar
Thanks a bunch. You guys are a great help.
Thanks again
John
jmccart
Mar 18, 2007 10:03 PM
jmccart
14
Nov 20, 2006 06:45 PM
amartinson
Jul 29, 2003 07:33 PM
My 03 HO
Jun 21, 2003 08:08 AM
