Edge Juice
Old Aug 19, 2005 | 09:17 AM
Dieselhed's Avatar
Edge Juice
Plan on taking the Edge Juice box off next time I get the truck serviced. Does anyone know if for some reason I have warranty work done they will be able to tell I had a box hooked up?
Old Aug 19, 2005 | 11:53 AM
HorseHauler's Avatar
its possible if they look careful they might be able to tell, but if its not going in for major work then they shouldn't even have to think about looking for one...
Old Aug 19, 2005 | 01:25 PM
RamWheelsBy4's Avatar
The techs are getting pretty good at this with some tips from Star. Check to see if your injector connections had a white seal painted on after factory connection. Unless the dealer has had to remove the injector connections this seal should not be broken. That is a visual simple thing. Any major drive train work would probably trigger a harder look.
Old Aug 19, 2005 | 05:39 PM
Dorkweed's Avatar
Muted User
From: "The Peoples Republic of Illinois".....behind enemy lines
The pyrometer cable that runs to nowhere may make them suspitious also!!!
Old Aug 21, 2005 | 03:56 PM
bigman's Avatar
The pyro cable is only if he has the attitude. For a routine service i wouldnt sweat it.
MrSuzuki
Aug 25, 2009 07:22 AM
razor6
22
Jan 20, 2006 03:43 PM
ataboy9026
Dec 28, 2005 05:06 PM
djcheez
Oct 15, 2005 04:13 PM
