E rated mud tires
Old Apr 12, 2007 | 03:06 PM
dodgemaniac's Avatar
how big would u guys suggest for my application and towing. should I get 2" front lift or not because of the towing?
Old Apr 12, 2007 | 09:22 PM
Jim Dynomite's Avatar
2" leveling kit and 35" Nitto Mud Grapplers! Yeah baby, yeah!
..............Jim
Old Apr 12, 2007 | 09:25 PM
what avout towing with 5th wheel and the 2" higher in front
Old Apr 13, 2007 | 04:13 AM
own1bigtruck's Avatar
the 305's are a 33-12.50/R17. The actual height is something like 32.6 inches. Not sure without doing the conversion, but im going to guess that they are just a hair taller than the 295's. I wouldnt run a 2" spacer in the front unless you have some way of bringing the back end up when the trailer is on to keep you level (ie: airbag system).
Old Apr 13, 2007 | 08:40 AM
jrussell's Avatar
So the 305's are wider but actually a little shorter than the 295's. 295's are about 33.4" tall. I wish they made a slightly wider version of the 295's.
Old Apr 13, 2007 | 08:33 PM
HUNTINNUT's Avatar
I Am Thinking About 235/80x17 Same Height As 285/70x17 But Not As Wide. Any Input Good Or Bad.
Old Apr 13, 2007 | 09:13 PM
boostjunkie1's Avatar
A 33-12.50-17 Tire is within a couple MM of a 285-70-R17 tire----Height wise! This is what I went with on my truck! ProComp did not make a 285 tire when I got the AT's, just a 33" tire. I like them because they are wider than a 285 and I play off the coast of NC on the islands and the sand is deep. The wider tire aired down helps out with the plowing that these trucks love to do in the sand!
Old Apr 14, 2007 | 01:01 AM
WUnderwood's Avatar
I have stock sized BFG All Terrain in Load Range E, and I really like them
May 29, 2009 10:24 PM
Alaska Sunrise
Feb 7, 2009 06:54 AM
buddy26
47
Jan 4, 2007 08:25 PM
sakisaki400
23
Dec 31, 2006 10:17 PM
Patrick Campbell
Dec 2, 2003 05:11 PM
