Dose yours do this?
Old Oct 18, 2006 | 05:22 PM
brickenbone's Avatar
Dose yours do this?
My truck will be idleing in park and about once every 60 sec. it will have a hickup.Changed the filter but still does it.Anyone else have an issue like that?Or am I just listening to much.......
Old Oct 18, 2006 | 05:28 PM
bigredBCS's Avatar
my 99 did that, and hopefullly its the not the same as what yours is doing, because it was the start of many problems. and i cant tell you what it was, because no mechanic that i brought it to knew. hopefully someone here does. good luck!
Old Oct 18, 2006 | 06:22 PM
lift pump ya think?
Old Oct 19, 2006 | 08:52 AM
GrandpasRam's Avatar
My '03 did that, and it turned out to be the return valve off the CP3; the CP3 was replaced under warranty.
Old Oct 19, 2006 | 09:03 AM
Dan Marino's Avatar
My SO has been doing something similar I think. It will idle up and then idle real low at a stoplight or when I stop after driving. It will idle so low that it almost acts like it wants to stall out. It seems to do this every other day or two.
Old Oct 19, 2006 | 09:10 AM
my idle stays the same but its like a quick hickup about every min. or so
Old Oct 19, 2006 | 09:37 AM
reecegr's Avatar
my 05 did the same thing for about a month went away on its own,never came back 4 months now.
Old Oct 19, 2006 | 10:54 AM
TRC51's Avatar
Mine only does it when it's cold. I pretty much disregard it because it is so quick. I think it does it more when I put it up on high idle, cause I don't notice it at normal idle.
Old Oct 19, 2006 | 11:21 AM
MikeyB's Avatar
Mine does it every once in awhile. Usually happens when the engine is warming up. My best guess is it's a glitch in the ECM programming.
MikeyB
Old Oct 19, 2006 | 11:45 AM
Smkn600CTD's Avatar
Only on warmup.........then when its warm, if the fuel filter has a bunch of miles on it, it will seem to have a ever so slight rough ldle......then go away.
Always been told its "normal"
Old Oct 19, 2006 | 12:38 PM
Bluedeviltorque's Avatar
This is just a HUGE guess on my part since I've noticed it too on my 03 HO and it only happens when its colder weather.
Could it possibly be the computer adjusting the injection timing a smidge where it reads the engines temp going up slightly? This sudden change would probally result in a slight skip I would think.
I don't know how exacting the ECM is with its controls or if its even capable of this... hence just a guess on my part.
....... Preparing for the experts to chime in and give a real response.....
MIke
Old Oct 19, 2006 | 01:10 PM
chromegrill's Avatar
mine does that when its cold, but its just the intake air heater cycling.
Old Oct 22, 2006 | 10:09 AM
jimmydodger's Avatar
mine did it real quick you could barley notice it then one day she just died on 600 miles form home. luckly warrentied coverd it. it was the dreaded lift pump. They said it was from running poor fuel. I was like what !! i dont get it .
bigbaddiesel416
Mar 18, 2009 10:09 PM
tboling
May 19, 2006 03:49 PM
Greguw
Oct 24, 2005 10:08 AM
ramlovingvet
Apr 22, 2004 12:28 AM
