Dim Lights on A/C Controls
Old Dec 11, 2009 | 12:02 PM
schorb's Avatar
The lights on my a/c and heat controller are dim and some appear to be out. If I tap on it, some of the lights get brighter, but soon dim again.
Does anyone know what's wrong and what I can do to fix this?
It has nothing to do with my dim switch.
Thanks,
Brian
Old Dec 11, 2009 | 12:43 PM
Ramtough's Avatar
Ill be interested to hear the answer to this as I lost half the lighting there too.
Old Dec 11, 2009 | 01:12 PM
billie's Avatar
If they change by tapping on them, it sure sounds like loose bulbs or connections. Take the dash apart and check, it's really pretty easy when you find the clip points. I haven't done it myself but my buddy took his apart in front of me in about 2 minutes.
Old Dec 12, 2009 | 07:42 AM
jhenson's Avatar
Had the same problem with my '03. Take a paint stir stick and carefully pry the trim off of the dash and take the screws out that hold the a/c control panel in and the little bulbs are a twist-in design. I think they were about $5 each at the local Dodge house. The same bulbs exist in your instrument cluster....I know from experience!! They aren't that difficult to access either....just remember that TIME is your best friend when doing that job.
danalex
Dec 27, 2007 01:39 PM
larry30000
Feb 26, 2006 06:29 PM
Hired Gun
Jan 24, 2004 07:55 AM
95ramtough
Dec 9, 2002 10:34 PM
