Diesel in Oil
Old Mar 14, 2007 | 12:25 AM
huntram's Avatar
Diesel in Oil
I have just over 36K on the engine. Noticed coming home today the truck was somewhat sluggish. Got home and it smelled like diesel was spilling. Looked underneath and oil was EVERYWHERE. It was spilling out of the crankcase breather tube. Checked the dipstick and it was WAY high. Smelled strong like diesel fuel. Had it towed to the dealership. They will look at it in the morning. What can I expect? Injectors? How about damage to the engine?
Thanks for the input...
Brian
Old Mar 14, 2007 | 08:02 AM
RyeThomas's Avatar
Winner winner chicken dinner!
Injectors, if they hang open they overfuel and fill the crank with diesel. What you can expect, is alot of cleaning as dodge will not clean it up nearly enough. And if I were you I would change the heck out of the oil and oil filter when you get it back to clean the diesel out. As it is now ULSD everywhere I have heard it can be ruff on bearings, and other internals. Best of luck. Rye.
Old Mar 14, 2007 | 08:31 AM
Diesel Doc's Avatar
I would change the oil twice at about 200 mile intervals just to be sure you get the diesel out and anything that it cleaned out of your crankcase out as well
Old Mar 14, 2007 | 09:11 AM
truckjunkie's Avatar
What they said, and MAKE SURE you remove your nerf bars, gauges, spray in liner, and your other non-engine related aftermarket items or the dealership will say that's what caused the injector failure.
Just kidding - I hope.
Old Mar 14, 2007 | 10:25 AM
deerefarm06's Avatar
yeah, your injector washed one of your cyls out and filled the crankcase with #2. Hopefully it didnt melt a piston, if you were driving it home and it was only sluggish, odds are your ok...either way, your warranty will cover.
Old Mar 15, 2007 | 03:22 AM
huntram's Avatar
They tell me the #3 injector has leaked fuel into the crankcase. they don't know if there is any damage and don't really seem interested in finding out. How can I pursue this? A friend suggested getting an oil sample to see if there is any metal shavings in it.
I change the oil way too often, like at 3500-4000 miles, I have about 2500 on this change, so other then the fuel it should be clean.
What say you??
Thanks
Brian
Old Mar 15, 2007 | 04:27 AM
DrDiesel's Avatar
Lightbulb
Have them fix the problem and change the oil. Run it and see. You have the failure on paper, so if it`s a problem you`ll have that as a starting point.
If you have all your receipts from oil and filter purchases/changes your covered for bearing failure.
Or you can pay to have the oil pan removed and pull all the main and rod caps for inspection. I would run it and see myself. Diesel is clean and it sounds like you found it quick. The odd`s are 50/50. Your truck = Your call... Hope this helps.
Old Mar 15, 2007 | 05:30 AM
P.J's Avatar
P.J
A quart sample of that oil they will be draining out would be nice. Give you an idea of the dilution. Maybe even for an analysis.
Old Mar 15, 2007 | 10:14 AM
DBLR's Avatar
I think a UOA is called for in this case. Be safe and spend the $20.00 and find out what you can from the oil.
Old Mar 15, 2007 | 09:09 PM
huntram's Avatar
Got a call back from the service guy today. Guess what...Even though yesterday I offered to pay myself for the oil sample, they claim they already dumped it, but of course they didn't tell me that until today ! I'm out of luck on it. They also say that Dodge has the injectors on backorder and no delivery date given. So my truck sits and I have nada!
I don't know if there jacking with me, or just a communication issue within the dealer. I'm kinda friends (our kids have played sports together) with the service manager, so I'm calling him tommorrow.
Brian
Old Mar 16, 2007 | 12:42 AM
annabelle's Avatar
Injectors.....
Old Mar 16, 2007 | 07:08 AM
Since they're backordered:
a) are they giving you a loaner vehicle, and
b) maybe you could tell 'em that since they can't get you stock ones, they should buy you a set from Don M. !!!
Old Mar 16, 2007 | 08:50 AM
53 willys's Avatar
Originally Posted by Pull U 2
Call DC customer service and ask them to help you. My LP went bad and the dealer gave me the dreaded backorder speech. I called DC and magically the backorder disappeared. LP was at the dealership the next day!
classic
ian515
Oct 16, 2007 07:02 PM
raven392003
13
Jul 2, 2007 06:52 PM
TxDiesel007
15
Jan 18, 2006 01:19 PM
JoeDiesel
Mar 18, 2003 06:24 PM
