Didn't start -- Battary Problem???
Old Jan 25, 2009 | 04:53 PM
papaduck's Avatar
Could be both batteries or just one battery is getting weak.
If you are on the original batteries as mine are, then they are 6+ years old. A long time for most batteries. I keep a close watch on mine and will replace both if one fails.
Old Jan 25, 2009 | 06:32 PM
RamWheelsBy4's Avatar
After almost 5 years on mine I had one battery that had a small slit under the post cable. It must have been slowly getting bad. I started having issues with longer cranks to start and then start and die and then not want to start. I checked everything else before the batteries. Found the slit and then went ahead and replaced originals with Optima Red Tops. I couldn't believe how much faster it spun and started. No more starting/cranking issues. I just did not realize over time how slow the engine was cranking when starting until if finally just did not have enough juice. It takes a lot of amps to start and run the grid heater and all other necessary things especially when cold.
Old Jan 25, 2009 | 06:57 PM
megacabdad's Avatar
Your not talking about this...
Are you?
https://www.dieseltruckresource.com/...d.php?t=121337
Old Jan 25, 2009 | 07:28 PM
megacabdad's Avatar
I was wondering, because the first time I saw my truck do that, I was worried that something was wrong...
Your batteries may be original, and if that's the way it is, 5-6 year old batteries need to be replaced, more or less, as a maintenance item, to eliminate them from being the problem...
Let us know what you find out after replacing the batteries.
Old Jan 25, 2009 | 09:11 PM
papaduck's Avatar
You said that you will replace the batteries, but if you don't, check the voltage of the batteries before you start the engine. Disconnect one battery and check the voltage of each battery. I'm not sure what the voltage should be but I think it should be more than 13 volts each.
If you check it with the batteries connected you will not get a good reading if one is bad. The best way to check a battery is under a load and watch how fast the voltage drops.
If the voltage of the batteries is low, I think the volt meter will stay low until voltage increases in the batteries.
Old Jan 25, 2009 | 09:45 PM
Originally Posted by st.rodder2
I don't think that's the same thing I'm seeing. What I'm seeing is when I first start up the truck after work, it doesn't appear to be charging. The voltmeter is down around 12 - 13 volts and stays there until after I start driving and reach 20 mph, then the voltmeter will begin to rise up to 14.5 - 15.
That is normal when the grid heater comes on. Mine will come on with temps as high as 45*. It will show low charge on the voltmeter until you reach 20mph, then the grid heater will turn off. Until then lights will dim, truck might sputter as the grid heater cycles.
440a-body
Mar 7, 2011 08:24 PM
NoSparkplugs
ABDTR #5
20
Oct 15, 2009 10:08 PM
greenworks
Jan 25, 2009 10:02 PM
red70ragtop
Mar 26, 2006 08:57 AM
