Did it to myself....
Old Dec 30, 2007 | 10:01 AM
  #31
menzy's Avatar
Originally Posted by Eddy Reyes
Menzy, a few memebers give you the right answer, your 4.5 wheels are just to much to the outside without a giant lift.
Here you go 35"s with leveling kit and a 5.5 back-space.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
The next one is a 4.5" lift and would not work unless a 5.5 back-space with a 9" wide wheel.
[IMG][/IMG]
How close are the tires to rubbing with the 4.5" Fabtech lift and the 5.5 backspacing, do you have any full pictures of that truck so i can see how it sits and what not as I think I may try it depending on what else i can find out, How does it ride with the fabtech coils???? I like the ride of the Lorenz coil, i think anything over stock has to be better..........
Old Dec 30, 2007 | 01:45 PM
  #32
Eddy Reyes's Avatar
Hi Menzy, not close to rubbing because of the 4.5" lift. My friends truck has a 4.5 back-space wheels with 6" lift and 35" 13.5" wide wheels, so it is possible.
Sounds like you really like the 4.5 back-space wheel look (Tonka Truck look).
The Fabtech coils are great, I added 2.25 Dirt-Logic shocks to it.
If you running out of options send a PM to member PTGarcia, he is an expert on this issue and may have other ideas
[IMG][/IMG]
[IMG][/IMG]
Attached Thumbnails Did it to myself....-img_0107_1_1.jpg   Did it to myself....-img_0205_1.jpg   Did it to myself....-img_0110_1.jpg
Old Dec 30, 2007 | 02:14 PM
  #33
menzy's Avatar
[IMG][/IMG]
[IMG][/IMG]
Hey Eddie:
Thats a good looking truck, I had my 2002 rocker panels lined like that, It worked out good as i drive lots of gravel. You are right, I LOVE the tonka truck look............ nose in the air, billet grile, and wide stance is a mean combo IMO.... So then you think I would be fine with a 4.5" lift under mostly normal driving conditions??? Do you have to do anything to the front driveshaft when you lift it that much????
Thanks again
morkable
54
Nov 18, 2007 05:35 PM
whatdieseltoget
Sep 21, 2005 12:46 AM
pappygtb
Aug 29, 2003 11:23 AM
Dodgezilla
May 18, 2003 06:02 AM
The Boss Hog
Oct 25, 2002 06:09 AM
