Desperate for help!
Old Jun 2, 2009 | 03:00 AM
walnutfarmer's Avatar
Desperate for help!
Ive been getting a p0237 code on my 04.5 for the past several months on and off. Dealer cant find anything wrong, and I have changed the MAP sensor and the sensor in the intake tube itself. I have tried removing my AFE but the code still shows up. Truck sometimes feels like its losing power until I step on it a little and it will get going again. Anything would help, I've spent $$$ on new sensors and for the dealer to tell me that they cant find anything.
Old Jun 2, 2009 | 09:41 AM
cdennyb's Avatar
From: In Oroville, Ca., same house for past 46 yrs!
well, considering everything you just mentioned uses a cable and connectors, I would first buy a couple of cans of contact cleaner and double or triple clean every connector I could find. Especially important is the TPS plug at the throttle cable/TV cable bracket under the plastic cover, then hit the PCM connectors (should be 3 of them at the firewall pass side) and then do the ECM cable down on the engine block. I had Overdrive problems that no-one could find for 3 months!!!! and then I decided to spray clean every connector. I solved the problem with a $4.00 can of contact cleaner and haven't had another one. I also had a MASS AIRFLOW sensor code about 4 months ago (dead of winter) and it too was contact cleaner repaired. Just a thought but it couldnt hurt.
db
Old Jun 2, 2009 | 11:36 AM
j-fox's Avatar
Where is a MASS air FLOW sensor on one of these trucks??
Old Jun 2, 2009 | 09:45 PM
rich's Avatar
check your wires running along the front of the motor could have chafed thru
Old Sep 23, 2009 | 01:00 AM
Ok I finally had the chance to do all of the above and still no luck. The code appears and disappears more often now. I have also had p0069 show up a couple of times. Any other ideas? Starting to get annoyed by this, i commute about 60 miles a day and get frustrated when it throws it self into "safe" mode. Could I be having turbo issues?
Old May 23, 2010 | 08:43 AM
mechanic1's Avatar
db
Hi, I wanted to ask what kind of contact cleaner exactly that you used....think I have connection issues myself and that sounds like a good place to start, cheap and easy.lol Bu8t I don't want to use anything that might damage the plastic in the connecters or harness.
Thanks,
Old May 23, 2010 | 09:01 AM
Totallyrad's Avatar
Are you still running the original batteries?
Old May 23, 2010 | 02:37 PM
mechanic1's Avatar
Yes, if you were asking me....my truck still has the original batteries.
Old May 23, 2010 | 03:11 PM
Totallyrad's Avatar
Sometimes when the batteries get old or weak they cause strange problems. I can't say for sure, just offering the information.
Old May 23, 2010 | 04:15 PM
mechanic1's Avatar
ok, thanks. I will keep it in mind. The batteries seem to be strong so far, no weak issues that I know of.
Old May 23, 2010 | 09:50 PM
Colo~Dirtbikers's Avatar
X2 on batteries.
If the voltage is dropping too far all sorts of goofy codes will set. Your truck will sound just fine. The batteries could be on the edge. Take em and have em checked with a good carbon load meter. Then youll know.
Bet they are past the limits.
Old May 24, 2010 | 05:44 AM
mechanic1's Avatar
OK. Will do.
Old May 25, 2010 | 04:16 PM
CoastalDav's Avatar
I looked up the codes. 0237 says; Turbo Boost Sensor, A circuit low.
0069 says MAP Sensor/Barometric Correlation.
Don't think this could be the problem, but thought I'd throw it in. "Windscreen"
posted a reply to a thread about a 5 volt wire that chaffed causing all kinds of codes.
Here is a link to the thread from 09. If the picture does not show up, I have it in my files.
https://www.dieseltruckresource.com/...ight=volt+wire
fass92
Apr 10, 2015 07:31 AM
FRESH68
Sep 4, 2008 08:09 PM
Meierznutz
Jan 23, 2005 11:18 PM
thumper 549
Jan 23, 2005 02:47 PM
thumper 549
Jan 1, 2005 04:09 PM
