denied and for what?
Old Jan 15, 2008 | 03:27 PM
  #31
bob4x4's Avatar
Originally Posted by coparam4x4
If he had the original paper work showing the reflash, and the mileage it was done wouldn't that be enough to throw it back in their face? BTW shouldn't it be their computer when the service(reflash) was done. If they can keep a blackball list of trucks in the computer then surely they have records of service performed.
A factory flash does not reset the mileage stored in the pcm................Nor does the moss act protect against warranty issues when increasing power,only like type parts with different mfgs not performance enhancements.
Bob
Old Jan 15, 2008 | 04:21 PM
  #32
Grodyman's Avatar
Originally Posted by rynemurch
Fight it I was just in the same boat when my trans went down so I took it in under warn work and the called me the next day saying they are not going to cover because i had a programmer on my truck. I told them to prove it and they told me they ran a computer on it and I said so. but i stuck with my guns and told them i didnt and did not admite to having one and they replaced my trans with a new $5800 dollars covered under warr. Thanks to marco ans smarty that it leaves no footprint!!!!!!!!!!! They have to prove it and show you!!!
Exactly. If you truly have not modified your truck, then you have this guy to thank. Truly disgusting.
Old Jan 15, 2008 | 04:53 PM
  #33
steelblitzkrieg's Avatar
DTR Detective
How would a downloader or box change your mileage? I could understand larger/smaller tires effecting your odometer, but how does the ECM compute mileage?
Old Jan 15, 2008 | 05:23 PM
  #34
nsxt's Avatar
So lets do a bit of math, shall we?
Old flash a while back says 38,xxx miles.
New mileage says 42,304
Old flash + new mileage = 70,304 + xxx
Odometer currently shows 73,936.
Just a few % difference.
Not difficult to believe the old flash erased the mileage now is it?
Old Jan 15, 2008 | 05:34 PM
  #35
vzdude's Avatar
DTR's 'Go to Guy'
Downloaders typically ( o.k. Smarty not included! ) erase key cycles and can affect SCI mileage written to the ECM. I have never had a Dodge of any kind erase mileage when doing a factory flash. Not saying it couldn't happen, just hasn't happened to me.
Old Jan 15, 2008 | 07:56 PM
  #36
Dartsport's Avatar
38,xxxmiles, plus 42,304 = 80,304 Not 70,304 ........
Old Jan 15, 2008 | 08:15 PM
  #37
rynemurch's Avatar
Actually my dealer knows that i run a smarty cause I go to the drags with them. The new general manager had a diamond man come check it out and the dealers diesel tech called me and told me to tell them to prove that I had a programmer on my truck so i did!!
Old Jan 15, 2008 | 09:35 PM
  #38
CamperAndy's Avatar
Who cares if you have a Smarty. Your dealer sees you drag race and you still expect to have it repaired under warranty? Bone stock and you take it on the track you can kiss your warranty good bye. Racing is a little outside of normal use and service.
Old Jan 15, 2008 | 10:34 PM
  #39
coiler33's Avatar
Well I may be dating myself but in the old days you could change the carb, cam and various other mods and still get warranty. Now they void your warranty if you take it out of your garage.
Old Jan 16, 2008 | 03:44 AM
  #40
chipmonk's Avatar
Originally Posted by ddestruel
A word to the many. DC just sent out a notice to all dealerships effective in december. a modified airfilter ( any air filter other than stock) holes in an air filter box, modified exhaust (any modification what so ever from stock) change in pipe diameter ect. is now grounds for voiding the factory engine warranty. its still to each dealerships discretion and mainly applies to the 07 and up trucks but still it should be noted. At a few dealerships locally i know of several cases where someone had aftermarket exhaust and a chrome tip installed on thier 6.7 and an air filter and they now own a 5k mile un-covered ticking smog bomb.
Good luck, they can claim all they want, they still have to physically prove.....a malfunctioning computer doesnt prove anything
one of the diesel techs at my dealership showed me a similar memo from dodge- several years ago! d/c has been issueing these memos regarding intake and exhaust mods for a long time, and it's up to your individual dealership as to how far they want to go to enforce it.
Old Jan 17, 2008 | 05:04 AM
  #41
BRayls's Avatar
Originally Posted by bob4x4
Bingo! They may have said programmer when they should have said box............semantics..........The edge raises rail pressure,known to shorten life of injectors the tst keeps them open longer,again Cummins did not build it that way.
Bob
this is not a war. I have not used a downloader on this ride at all, period. I do want a few opinions about the statement above. yes cummins did not build it that way I know.also know it should not be covered if it has a tst, not the point. but in reality what is the tst doing to the injector that is was not designed to do? it opens it and allows it to close, just at differant time correct? I can see voiding the warrantee on the engine for damage but the injector, it was designed to open and close right? timing has no ill effect on its function. or am I missing something? this was just a thought I had last night.
Old Jan 17, 2008 | 09:05 AM
  #42
welndmn's Avatar
A programmer does the same thing. It holds the injectors open longer as well.
What do you think is the difference between a programer and a box?
Really, if I were you, I'd be nice to them, and just go to another dealer.
If you are a jerk to them, they will red flag you on the computer, and you won't get warrenty service from any dodger dealer.
Many dealers when they see something like this, they just mark it on their local system.
Old Jan 17, 2008 | 09:37 AM
  #43
sweeney186's Avatar
Yes injectors open & close,but think about it this way-your engine has a redline of say 4000 rpm-you can run it for short periods at that rpm & be ok-but run it close to redline for a long time & its not going to last that long
Old Jan 17, 2008 | 11:32 AM
  #44
CD in NM's Avatar
So, you are a few days into this, have you made any progress with getting your warranty issues and arguments in order with your dealership? Have you returned to them and asked for their proof that underlies their denial? Have you contacted/involved Chrysler in this matter?
CD
Old Jan 17, 2008 | 12:00 PM
  #45
CrazyFloyd's Avatar
I took my truck in as is with the mods listed (just removed the xzillaraider box) when it was leaking antifreeze. They warranty the work and I paid a 100 deductible. Then 4 months later they credited the credit card I used and I still don't know why but I am not asking any questions. So like everyone else says it is really who you take it to if they are still gong to honor the warranty.
