Dealer Voided My Warrenty
Old Mar 27, 2008 | 08:27 PM
  #136
SolarExpress's Avatar
Do to recent additions to this "thread", I feel compelled to be "in before the bin".
Old Apr 8, 2008 | 09:25 PM
  #137
easydoesit's Avatar
transmission shudder
Originally Posted by charger7022
the 48re sucks power or not it was going when i got the truck plain and simple automatic trannies are not for diesels! Next truck 6 Speed!!
So I own a 2001 2500 diesel 6 speed and since 85,000 km the tranny been out 4 times - 1st to repair 6th synchro and 5th gear damage discovered shortly after I purchased truck, 2nd time I told dealer that 3rd gear feels like it is going - mechanic pulls tranny and says 3rd gear ok you need a clutch - I humor him and let him install new clutch - 8,000 km later back at shop for 3rd gear, get truck back and front seal leaking - out it comes again, next oil change I see oil leaking from top of tranny - @#$% dealer hadn't tightened shifter tower!!! How much of the above was mechanic incompetence - you tell me? I am far from being an aggressive driver.
Been following this thread with hopes of finding out why my 2006 MegaCab 3500 4x4 diesel shudders when I accelerate from a standstill. I usually accelerate very moderately but still the shudder. Happens empty or when I pull my 13,000 lb fifth wheel. Seems to pull it ok after that initial "lift the load" shudder. It has done it since about 90,000 km and I am now close to 150,000 km.
Any help would be appreciated.
Old Apr 9, 2008 | 06:32 AM
  #138
JP-4.5's Avatar
easydoesit,
If you search around the site for shudder or rear pinion angle you will find articles with similar problems as you are stating. I think most people had the shudder either empty or loaded not both? I believe they change the pinion angle by adding/removing spacers under the center carrier of the rear driveshaft.
Hope that gets you in the right direction as the other area would be if your converter is getting tired as I think it can also make the truck shudder.
Jeff
WEATHERBY460
Jun 18, 2006 12:37 PM
tanderson2002us
25
Apr 18, 2006 11:08 PM
Badd Dogg Guy19
Nov 8, 2005 10:53 PM
jefe4x4
14
Jan 16, 2005 01:55 AM
TXSST
May 24, 2003 02:35 PM
