ctd fuel mileage
Old Feb 22, 2010 | 05:40 PM
04600CTDRAM2500's Avatar
Question ctd fuel mileage
l was wanting to now what range is every one getting for fuel and how hard,soft your driving. im getting around 22 ive seen on my auto 25oo 6ft bed 19 on one trip and 26 on other trips
Old Feb 22, 2010 | 06:57 PM
Lost Lake's Avatar
I just found out the overhead display maxes out at 98.8 mpg. That's what I was getting in the Tennessee mountains.
Old Feb 22, 2010 | 07:22 PM
Cool Real Mpg
I Guess If I Started At The Top Of The Hill And Reset It I Would Get 98.8 Also. Be Real Want A Real Answer Cause For A Bigger Truck I Hear Fords And Chev's Get Way Worse Also Other Dodge Ctd 2x4 Are Getting 15 Or So When You Topoff Your Tank What Does It Say? My Has Gone Up To 816 Really Topoff And Said 816 On 35 Gallon Tank And Drove Home 70 Miles And Still There
Old Feb 22, 2010 | 07:51 PM
93-331-29psi's Avatar
I usually get 21.5 hand calculated, and that's driving normal. No hot rodding around. On road trips I have gotten as high as 26mpg. About 850 miles to a full tank, but that was me keeping it around 60 and using cruise.
Old Feb 22, 2010 | 08:05 PM
Redtech1's Avatar
iI get 21-23 by hand overhead reads 24-27. I try to stay at 68mph on the highway and what i call normal driving (not racing at every light) around town.
Old Feb 22, 2010 | 08:26 PM
OCMerrill's Avatar
Not quite as high as some of the mileage quoted but here in so cal combo freeway/city I pull consistent 17-17.5 mpg.
On a recent trip to the Colorado River and back I pulled 22.5 running no faster then 70. A/C on the entire trip.
These are hand calc'ed and I find the overhead display off about 3% if you reset it each tank and runs off even further if you "let it roll" and compare it back to totaled gallons on paper over a number of fill-ups.
For best results, reset the overhead every tank.
Truck is 100% stock.
Old Feb 22, 2010 | 08:49 PM
NickBeek's Avatar
Well I'm not as high as some but I'm happy with the number I get. Not in town driving 65 or less I get between 18-20. I don't do very much in town driving so I can't really give you a "city" number. My best ever tank was 21.652mpg and worst ever pulling my camper at 70+ was around 9.799. I log every tank and always fill it till it won't take any more and my lifetime average is 18.316mpg. My last last six tanks average to 19.7 mpg.
As far as other trucks, I had a '99 F250 I didn't log every tank like I do now, but the best it ever did was around 19.xx mpg, I also had a '04 6.0L Ford that averaged about 17.xx mpg.
Old Feb 22, 2010 | 10:16 PM
Exclamation fuel mileage
does anyone run additive for injector cleaning and get better mileage or just feel more power ?.it seems to me i get a little of both i run some juice about every 15- 20k . do you think any one brand is better than another? i put the tornado in my air intake witch is in the wrong spot as far as i know .seems to help i think. its supposed to go between the intercooler out hose side and the engine block (CANT THINK OF THE CORRECT TERM SORRY) wana get better mpg any ideas.......................
Old Feb 22, 2010 | 11:26 PM
bucknasty's Avatar
Weird....I've got the same truck except mines a short bed! I get exactly 1/2 of what you're getting. I don't see how that's possible. I'm talkin grandpa driving will net me 12.5 mixed. I NEVER EVER EVER get over 400 miles before the light comes on. Why can this be? I swear I'm the king of low mileage vehicles....everything I have ever owned get 12.5 Miixed! Toyota's, Fords, Chevys.
Old Feb 22, 2010 | 11:31 PM
1-5-3-6-2-4's Avatar
what volume of fuel do you put in the tank?
thats seems way out of line, unless there some major mechanical malfunction causeing the poor mileage. I'm curious now.
Old Feb 22, 2010 | 11:49 PM
annabelle's Avatar
Big difference between an 04 and an 06. If you are only getting 12.5 mpg then something is wrong.
Old Feb 23, 2010 | 12:40 AM
Question mph
i dont my gears but may be there is the difference .can it be u only drive in town. i drive a mountain road up n down then on the flats try to drive between 60 and 68 . how many miles are on your truck cause my truck started getten better mph around 50k when my engine was broke in fully . i try to let the torque move the truck instead of power such as letting the truck start rolling at the red lite to get moving just that much so i dont have to stab it to get going . my truck is a short bed and a HO .that is very strange (filters have a big play in diesels )
Old Feb 23, 2010 | 12:46 AM
bucknasty's Avatar
Most fill-ups are 29-30 gallons and add 1/2 bottle of Marvel.
Truck has 39k on it and it's all mixed driving. I think the city mileage is what's killing me.
Old Feb 23, 2010 | 01:11 AM
marvel mix
i use the instructions on the bottle . so maybe youll get better mpg sooner than later with more miles on the truck but i never got that bad . used to carry a 90 gallon fuel tank in the bed full and drive fast and still was getting 17ish . fast as in 70 80 mph lost my fuel card from work so now drive way grampal at least on the way to work may be speed limit on the way home live in ca. so most speeds are 65 ill try to find more on this asap then post again on this this is 4x4 auto short bed if i didnt say before
Old Feb 23, 2010 | 06:54 AM
skindaddy's Avatar
i'm in the same boat as you same miles on truck if i hand figure my intown if lucky i get 14mpg, never ever seen 20 + on highway . at best maybe 18.5mpgs.(thats with smarty settings) worse if stock. I always ask if there is a flash for this but there is not. i also wonder maybe the valves are off adjustment if that could net bad mpg's. i wish i knew how to check them and adjust them, also scared i might mess something up if i tried!!
