Cruise control
Old Oct 19, 2018 | 07:54 PM
td3620's Avatar
Cruise control
My uncle truck cruise control quit working on his 2003. Set at 65.then drop.then go back up. Now it don't work anymore
Old Oct 20, 2018 | 10:02 AM
gcssr's Avatar
There is a vacuum pump between the battery and firewall{passenger side} also a black plastic tube that crosses over to the center of the firewall, that supplies vacuum to cruise control, this tube cracks and with that goes cruise ;;;
Old Nov 22, 2018 | 09:07 AM
Lancer300's Avatar
Tell your uncle to look at the cruise servo i think it is. Its under the driver side fender. You need to remove the wheel arch to get to it. 3 small bolts hold it on. It has a wire that goes to the the throttle on the side of the intake (Where the apps is located) i had to replace mine.
Same issue as you had. I got a second hand one from ebay just to try. They are the same as on a Jeep Liberty i believe, youjust need the bracket from the truck swapped onto it.
Saves a few hundred beer tokens
tobyw
Oct 26, 2018 02:29 PM
Firstgenfanatic
Nov 8, 2009 04:05 PM
Landini1
Mar 6, 2009 07:01 PM
trophystock
Jul 6, 2006 06:28 PM
TexasDiesel
Dec 27, 2002 10:47 AM
