crank with block heater ON cause code on 06?
Took my truck in to get the high idle enabled as well as the check engine (PO514 and PO513) checked out. the flashed tsb's 18-003-06 and 18-005-06. so far it has fixed the problem...but the truck now idles at 800 not 750 "for improved charging"
I'm in Northeastern MD, we have the most disappointing climate in the US. I tell myself every winter that I need to be in the Carolina's somewhere.
Sometimes geography dictates temperature, no?
don't matter to me - mama gets cold, she whines.
she whines - my ears hurt
solution: plug the truck in & have it warm for her.
it went away after ~5 key cycles by itself.
Thanks Bluebill ! I figured everyone had me on iggy
I went through the exact same thing last fall when I bought mine. Been there done that. The dealer is the only one that can really fix it with a flash! Mine even got better milage after it was done!
I'm in Northeastern MD, we have the most disappointing climate in the US. I tell myself every winter that I need to be in the Carolina's somewhere.[/QUOTE]
Let me know, I can hook you up with some real estate!
TSB 18-05-06....that was the flash they used a year ago. I'm sure they are on a new version. Or I wrote it down wrong and it was a 18-005-06. Either way the problem is gone and the MPG improved.....good luck!
well, they done about 4 or 5 TSB's today,
and of course, they did not do the High Idle TSB like i asked....anyways..
got those 2 done, got code cleared,
did reset of overhead, showed 22 mpg on way home....uumm...maybe optimistic, but it will probably come down to normal with more driving.
tks for the data
FWIW, the mechanic said, "yeah, I just took the DRB3 out to every new truck and flashed them all when they came out with that TSB, why make a guy pay that for a truck, then have to come right back in the next day for a SES?"
tks for the data
Pythonater
0
May 22, 2010 10:09 PM
supersonictoys
Nov 8, 2008 09:17 PM
county cowboy
Jan 27, 2008 08:51 PM
Diesel-Dan
18
Jan 21, 2005 08:13 AM
