CP3 Question?
Old Mar 16, 2010 | 03:23 PM
Diesel87's Avatar
CP3 Question?
I know on common rail trucks the injector controls the timing and all the cp3 does is pump fuel. This is probably a stupid question, but does it matter that I turned the motor over while having the CP3 off the engine? I had the pump off when I was installing my new valve springs, and wasn't completely sure about starting the truck without knowing for sure. Thanks.
Old Mar 16, 2010 | 04:11 PM
fl dodge's Avatar
no the cp3 shaft is not keyed or anything like that it`s just a tapered shaft put it on and start it up
Old Mar 16, 2010 | 04:23 PM
Diesel87's Avatar
Good. I have already put the cp3 back on, just wanted to make sure i wasn't going to hurt anything. Thanks.
Old Mar 17, 2010 | 09:05 AM
no_6_oh_no's Avatar
Won't hurt anything at all. If you get a hard to find rattle that sounds like timing knock you may have to phase the pump to the engine.
Old Mar 17, 2010 | 06:59 PM
JJPage's Avatar
Ditto!!!!!
Old Mar 18, 2010 | 07:51 AM
shawnsam's Avatar
Could someone explain pump phasing?
Old Mar 18, 2010 | 11:45 AM
no_6_oh_no's Avatar
The CP3 has a compression cycle that compresses the fuel for the rail pressure, same as the engine has a compression cycle that compresses the air. When these 2 are out of synch it can cause noise in the CP3 gear drive form the lash slapping on out of synch compression cycles.
Its commonly called timing the pump but its really phasing the compression cycles between pump and engine so they coincide.
Old Mar 19, 2010 | 04:05 PM
shawnsam's Avatar
Thanks for sharing the knowledge.
adamsmarshall
13
Oct 7, 2008 06:54 PM
Jethro6213
19
Jul 11, 2008 11:59 AM
pullin hard
Mar 18, 2008 03:57 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
