cp3 leak
Old Jan 14, 2006 | 08:36 AM
  #91
wexman's Avatar
What is SPECK? Hold 5psi at WOT full load?
I was curious about this as well.
Old Jan 14, 2006 | 07:04 PM
  #92
Disel Dave's Avatar
Scott check your PM's
Old Jan 16, 2006 | 06:26 AM
  #93
sawboywv1's Avatar
Got the FASS pump installed so we'll see if the CP3S stays good.
Old Jan 17, 2006 | 06:12 PM
  #94
wexman's Avatar
They started on mine today, but called late this afternoon to say it's "taking a bit longer...".
Now THAT makes me nervous.
Old Jan 17, 2006 | 06:22 PM
  #95
Buzzer's Avatar
Scott...I think the book gives them and hour and a half but not sure. It does take some time though so I wouldn't worry or be looking to buy spare parts quite yet.
Old Jan 17, 2006 | 07:06 PM
  #96
wexman's Avatar
LMAO!!
Old Jan 18, 2006 | 01:26 PM
  #97
wexman's Avatar
Dealer called, truck is ready. NOt only did they replace the Cp3, apparently I had a leak at the cylinder head, for which they replaced an O-ring, also under warranty.
Service advisor seemed a bit confused about that one, I'll have to take a look at the invoice tonight.
Old Jan 18, 2006 | 06:02 PM
  #98
wexman's Avatar
Replaced the CP3, apparently I also had a leak at the cylinder head, for which they replaced the fuel injector connector tube and O-ring, also under warranty.
He cleaned up the engine compartment nicely. Gotta admit, looks like he did a good job. I'll know in the morning when I leave for work if there are any new leaks.
Old Jan 19, 2006 | 03:26 PM
  #99
sawboywv1's Avatar
I hoped they checked ur lift pump!!!!!!!!!!!
Old Jan 19, 2006 | 09:51 PM
  #100
wexman's Avatar
No they did not.
Old Jan 20, 2006 | 12:46 AM
  #101
Hounddog's Avatar
Bet no wone will until trucks are towed in.
Old Jan 20, 2006 | 06:42 AM
  #102
evan4434's Avatar
CP3 Leak
I have a 2004.5 that had a CP3 leak, and I my fuel pressure is 12 psi at idle and 5-7 at WOT and that is with my edge on number 1. I have a stock lift pump and always have more than 5 psi (which is the danger zone) and my CP3 still went out. By the way I have 30K miles and have had 2 programming updates, had the clutch pedal fixed twice, CP3, front hub, and rear u-joint. It is a good thing I love my truck, or I would have gotten rid of it a long time ago. I also have a BD OEM lift pump bypass system on the way. This way there will be no questions about my lift pump being the case of a CP3 failure in the future.
Old Jan 20, 2006 | 06:50 AM
  #103
Hounddog's Avatar
How about a link to the BD oem lift pump bypass system.Thanks
Old Jan 20, 2006 | 07:55 AM
  #104
sawboywv1's Avatar
Mine just leaked, they never failed. I eliminated my lift pump with a FASS pump system about 250 miles ago. We'll see what happens. They factory lift pump seams to be an on going issue with the fuel supply problems. Superduty beat it in the ground and I have to agree with him. If the ligt pump does not fail it slowly looses its pressure and ghr ability. I noticed after draining the filter housing that the factory lift pump took 5 times longer to refill than the FASS pump & it's only the 95ghr pump!
Old Jan 20, 2006 | 09:19 AM
  #105
evan4434's Avatar
Bd Oem Bypass Kit
http://www.bd-power.com/ram/product....%20Kits&tt=ram
If you click on there pricing and application link. You can see the part number and price for the oem bybass kit. The also sell an auxiliary Lift Pump Kit.
adamsmarshall
13
Oct 7, 2008 06:54 PM
Jethro6213
19
Jul 11, 2008 11:59 AM
pullin hard
Mar 18, 2008 03:57 PM
BADBOWTIE
28
Jul 14, 2007 02:36 PM
megacabrule
33
May 10, 2007 01:07 PM
