Need to raise front end on 04.5 3500 2 wd
Old Jan 19, 2006 | 11:09 AM
hauliday's Avatar
Hey guys i am looking to raise the front on my 2 wd 3500 i was wondering if any one has done it with custom springs i really dont think the spacers will hold up it is almost sitting on the bump stops now
Old Jan 19, 2006 | 11:35 AM
MikeyB's Avatar
Here's the thread on lifting 2wd trucks with the 1.5" Daystar coil spring spacers.
https://www.dieseltruckresource.com/...ad.php?t=86957
MikeyB
Old Jan 19, 2006 | 09:55 PM
larryt's Avatar
Front Coils
http://www.coilsprings.com
They will e-mail a quote based on the info you provide in
their form. They quoted me just under $200 plus shipping
for a 1 1/2" lift for my 2500 2wd. This is for a pair of front
springs.
I'm still pondering whether of not to order. Not sure if I'll
need a spring compresser or special tools needed , etc,.
Larry
Old Jan 19, 2006 | 10:21 PM
hauliday's Avatar
Revtek Lift for Dodge 2500/3500 2" Leveling Kit 1994-2005
http://www.central4wd.com/inventoryd...;folder%7C5297 I found these and they are Powder coated cast aluminum construction. I think they might be better than the daystars
Old Jan 20, 2006 | 07:11 AM
MikeyB's Avatar
Don't think the lifts for 4wd will work on 2wd models.
MikeyB
Old Jan 20, 2006 | 10:04 AM
01350banshee's Avatar
Gents,
the 4wd lifts will NOT work on 2wd's, Daystar has 1", 1.5" and 2" lift pucks. Ordered a set of 1.5" pucks Tuesday for $68.00 minus shipping and tax from my local 4x4 shop. 1.5" pucks work well, they leave just a slight nose down angle. 2" pucks will require new a-arms and shocks. This came directly from Daystar. As for what I've been told and seen, it will also remain level when you got stuff out back. But, I have seen folks go with a 1" rear block just to be sure to not have the azz down look when loaded. I will post pics once installed.
Old Jan 20, 2006 | 10:26 AM
RustyJC's Avatar
Hmmmm....every leveled truck I've seen squats noticeably in the rear with a heavy 5th wheel hitched up to it. Our 5th wheel just levels out our 2nd gen 2WD dually that sits at stock ride height. I guess it depends on the stuff you have out back.
Rusty
seanrocks
Mar 20, 2009 06:59 PM
redneck2thamax
Nov 14, 2007 04:54 PM
royta
Feb 12, 2007 11:04 AM
pappygtb
Oct 10, 2003 07:55 PM
