A couple of basic questions.
Old Feb 27, 2008 | 12:55 PM
wanna2500's Avatar
OK, I am a new Cummins owner and have a couple of beginner questions.
1. At what speed does you torque converter lock up? I ask because when I bought the truck it already had 295 tires on it and the speedometer was off. I took it in and had the dealer recalibrate it and now the TC locks up at a slightly different speed.
2. How much vibration should I expect at idle? As soon as I let off the gas pedal to coast or come to a stop I have enough vibration to shake the keys in the ignition. I don't think it is too excessive for a diesel but figured I'd ask.
Thanks in advance.
Old Feb 27, 2008 | 01:50 PM
Dieselnick's Avatar
First of all theres no g in Cummins.
After a re-flash for tire size it should lock at a different speed.
Vibration at idle is normal. The stacks may be adding to it.
Nick
Old Feb 27, 2008 | 01:59 PM
wanna2500's Avatar
Nick,
Thanks for the info, I was wondering the same about the stacks. Sorry for the misspell. Typing a little fast I guess.
The TC lock up changed by about 1-2 mph it seem.
Thanks.
Old Feb 27, 2008 | 02:59 PM
txfiremedic's Avatar
Welcome to DTR! A little shaking is normal, but shaking enough to rattle your keys? I don't know, don't have any experience with stacks but I can't imagine it causing that much shake. Maybe someone else will chime in here on this one. As far as the TC lockup, that sounds normal!
Old Feb 27, 2008 | 11:46 PM
jestes's Avatar
Hmm... Do you have a hard knock at idle or just above it? The engine should shake a little at idle, but not so bad that it's shaking mirrors/keys or anything.
Old Feb 28, 2008 | 07:02 AM
wanna2500's Avatar
No hard knock, it just shakes loose keys that are together on the key ring that hangs from the ignition. I think the stacks might have something to do w/ it, as stated above. After checking they might be vibrating where they come through the bed.
Anyone know what mph their TC locks up?
Old Feb 28, 2008 | 08:40 AM
jestes's Avatar
Should be 48 mph, or a little higher if your accelerating hard.
Old Feb 28, 2008 | 09:17 AM
mikewalling's Avatar
There is a Technical Service Bulletin Concerning excessive vibration at Idle.
It is TSB18-015-05 REV.A
It involves replacing the dual mass flywheel
Old Feb 28, 2008 | 11:04 AM
wanna2500's Avatar
Jestes, thanks it looks like mine locks around 52. I wish it were a little lower, as some of the roads I travel that speed is a little too high.
Mike, no flywheel, automatic trans.
Thanks guys.
Thedieselkid
Apr 7, 2008 11:17 AM
ScottGregory
Jan 31, 2008 06:29 AM
welndmn
Jun 18, 2007 11:41 AM
robsredford
Nov 22, 2006 12:39 AM
