Couple of 03 ram 6spd transmission questions...
1) I am getting a whining noise most noticable when in 6th gear at speeds above 50mph. The whine becomes most annoying at 62mph and stays around until 75mph (as fast as I have gone so far). The whine goes away when you leave off the throttle and comes back again when you are traveling/maintaining speed on the throttle or accelerating.<br><br>2) I am also getting a relief in the whine when I coast down a hill (see #1 above), but sometimes I get a wierd noise from the transmission like something is slipping, you can feel the slip in the transmission shifter....any thoughts?
Re:Couple of 03 ram 6spd transmission questions...
Hummin,<br> That does not sound good
I have no such noise on mine. The noise you describ sounds like gear whine caused by low lubricant. My advice is to get it to your dealer as soon as possible.<br>The Boss Hog
Driving in the Rig while the noise is happening...if I keep my head forward the noise is prevalent...if I turn my head 90 degress toward the passenger it "seemingly' goes away.<br><br>I am getting concerned that no one else has this "whine" while driving in 6th gear.
YEah, I had those go bad already...this seems a little more local to the cab.<br><br>Although I could be wrong.<br><br>I am hoping the dealership checked the rear axle for fluid prior to me bringing it home...especially when I requested the axle fluids be checked and the salesdriod noted it was part of the procedure.
Now you aren't talking about turbo whine are you? Mine whines nice and loud on uphill and towing and totally quiet downhill.When you really get on it it sounds like a semi coming up on you and once you back off it quiets down quite a bit. The older cummins engines were loud enough with engine noise that you never heard the turbo whine muchunless you bombed it a lot, but now with our quiet engines you do noticeably hear the turbo.<br><br>Monte
<br>Now you aren't talking about turbo whine are you? Mine whines nice and loud on uphill and towing and totally quiet downhill.When you really get on it it sounds like a semi coming up on you and once you back off it quiets down quite a bit.<br><br><br><br>'specially if ya yank the silencer ring and the black plastic thingie ;D ;D ;D.
[quote author=Hummin' Cummins link=board=20;threadid=11462;start=0#108995 date=1046204716]especially when I requested the axle fluids be checked and the salesdriod noted it was part of the procedure.[/quote]<br><br>IMHO you are putting a tremendous amount of faith in the fork and spoon operator in sector 7-G<br><br>Good Luck
I towed my boat for the first time today and the turbo whin has my ears ringing. It is at the exact RPMs you talked about. I know some like to hear it but I don't. It was a great pull.
<br>I know what a turbo sounds like (owned 6 turbo cars and 2 turbo trucks now)...definitely not like the whine I am hearing.<br><br>The whine I am hearing is gears or bearings.<br><br>More like a bad rear lash setup.<br>Bad rear carrier bearing.<br><br>Bad tranny bearing<br>Steep (almost straight)cut tranny gears on 6th which a whine would be natural<br>or<br>Low on oil somewhere.<br><br>Will find out Friday AM
Everything is good an the noise I hear is normal according to the Tech. <br><br>It is probably all in my head as you guys have me worried.<br><br>Fluids were full...I watched them check it and put the plugs back in.<br><br>changed engine oil while I was there.
Not to worry you but--<br>My dad has a 99 3500. 125k on his 5600 and the main input shaft bearing and 5th gear syncro's are toast. He had distinct growling kinda noise while driving.<br><br>Mine is starting to growl- :'( :'( :'(
dlcope
Nov 9, 2010 11:58 PM
Hummin Cummins
Nov 9, 2009 02:53 AM
westport
Nov 24, 2005 01:43 AM
possum
Jun 4, 2005 10:47 AM
