Could there be any damage?
Old Apr 16, 2007 | 11:18 AM
powerstrokin03's Avatar
Sunday night, i was out cruising around. Stopped at a stop light turned my TST up and got on it. The next thing i knew i was puffing white smoke and the truck felt as if it were running on 2 cylinders. Pulled over and started checking. Finally a discovered 3 out of the 4 bolts on the crank pullley had come loose. I suppose this is what caused all the white smoke and horrible running. I tightened them all back up and drove home. Putt putted all the way home around 10% throttle. My concern is, could anything bad have happened to the motor?? Just want to make sure before i drive it hard again.
Old Apr 16, 2007 | 11:55 AM
dodgezilla04's Avatar
since the pulley retains the tone ring for the crank position sensor, you probably just really confused the poor thing with the timing jumping around. after tightening it up, how did it run on the way home?
Old Apr 16, 2007 | 12:23 PM
ran fine, a little bit of rattle though, what way do you turn the tone ring to retard the timing? if you are looking at the front of the truck?
Old Apr 16, 2007 | 12:24 PM
but other than that you dont think anything else could have happened?
Old Apr 16, 2007 | 12:35 PM
the engine rotates clockwise when looking at the front. to retard the timing, rotate counterclockwise. there is only a tiny bit of slop in the bolts and alignment dowel. doubtful there is enough play to change the sound. but that's the direction to go.
Old Apr 16, 2007 | 12:46 PM
well ill give that a try and see what happens. Thanks for your help
Old Apr 16, 2007 | 12:47 PM
you're welcome, good luck
king d
NCDTR #18
Sep 7, 2008 09:41 PM
mainer
Oct 23, 2007 02:42 PM
53 willys
May 20, 2007 09:21 AM
Ian
Mar 13, 2005 10:31 PM
Eat Beef
Dec 19, 2002 12:03 PM
