coolant leak from plugs on manifold
Old Jul 9, 2005 | 11:46 PM
jerry007's Avatar
I have had coolant leaking around those plugs on the manifold.(on top right next to valve cover) They don't leak much, but it still annoys me. Dealer is supposed to get them replaced. Still under warranty. Anyone else had this problem?
Old Jul 10, 2005 | 12:48 AM
larryt's Avatar
Yes a year or two ago there was talk of it in some of the forums, on the 2003 model. There was
a TSB issued but I don't know the number, sorry.
Old Jul 11, 2005 | 05:33 AM
Hounddog's Avatar
Takes all of a minute to tighten them a turn or two.All the ones I've looked under the hood at ozzed.
Old Jul 11, 2005 | 08:35 AM
nickleinonen's Avatar
not even that much is needed to get them to seal.. they are standard NPT pipe plugs. grab the right size tool and tighten them up a bit, or if you like, remove it, clean the threads, apply a little permatex #2 to the threads and reinstall it... i don't know how much coolent you will loose pulling the plugs though???
Old Jul 11, 2005 | 12:03 PM
SBishop's Avatar
Just tighten them a little bit. Takes all of a few minutes and you won't even get your hands dirty!
Old Jul 11, 2005 | 10:05 PM
Mark Thomas's Avatar
Mine leaked from day 1, dealer fixed on day 2.
Old Jul 12, 2005 | 04:01 PM
jerry007's Avatar
Thanks for all the advice. I think I will just try to tighten them up a little
Old Jul 13, 2005 | 05:23 AM
N.Johnson's Avatar
Yup I had the same thing happen. Checked the 1/2" pipe plugs,passenger side of the block and loose as a limp wristed ....... Anyway torque the 1/2" plugs to 40 lbs. no more and use a torque if you haven't twisted pipe threads before...careful it is easy to mess up. While your at it check the 3/8" (one only,same side) should be 20 lbs. Hell when I first noticed this I checked all the **** bolts and found many loose or strong armed. Remember guys this engine is mass produced and transfered to mexico for install. Can't hurt to check on the one we love does it?
CLS LLC
Nov 28, 2010 09:57 PM
george7941
Nov 28, 2009 09:28 PM
kyachovitz
Apr 23, 2009 02:45 AM
RyeThomas
34
Oct 13, 2008 10:47 AM
Cummins600
May 8, 2005 09:53 PM
