Coolant Drain Interval
Old Aug 1, 2007 | 05:37 AM
Mark Hodowanec's Avatar
When should the factory filled coolant be drained out?
What is the recommended coolant for the Cummins?
Old Aug 1, 2007 | 10:03 AM
Roperteacher's Avatar
Most of the new trucks come filled with the 5 yr 100,000 mile coolant. Depending on which you reach forst. For me, the 100,000 miles!
Old Aug 1, 2007 | 10:04 AM
Forgot the 2nd part of your question. I believe your 04.5 requires HOAT. Go to the auto parts store and the Zerex G-05 is the best. I believe the Dex cool also says OK for truck 2001 and newer ( Chrysler) and compatible with HOAT requirements. I read that last night as a matter of fact..
Old Aug 1, 2007 | 05:09 PM
rjm022's Avatar
like stated earlier-zerex g-05-it is in a gold container. advance auto does not carry it- but autozone does- about 10.00 bucks a gallon!
Old Aug 1, 2007 | 07:48 PM
DECEPTiON21's Avatar
How much coolant does it take?
Old Aug 1, 2007 | 10:50 PM
I believe an 05 takes the same as my 07 5.9 which is 7 gallons I believe!
Old Aug 2, 2007 | 01:13 AM
TexasCTD's Avatar
http://www.valvoline.com/pages/produ...asp?product=10
Old Aug 2, 2007 | 02:30 PM
DBLR's Avatar
My self I would not use any thing that has Dex cool in it in my engine being it's not a Chevy/GMC product, as I've read a few bad stories about it. Only use HOAT coolant that is rated for use in your CTD engine (I've heard that Zerex G-05 is Ok to use but double check to be sure) and only used distilled water, Do Not use tap water to mix in with your coolant.
Old Aug 2, 2007 | 09:39 PM
WhoozYaDaddy's Avatar
100,000 miles, or 5 yrs. whichever comes first. Use MOPAR or Valvoline GO5 HOAT Coolant.
klx650a2
Jan 10, 2008 12:08 AM
wooff
May 1, 2003 11:22 AM
jethroish
Feb 17, 2003 06:28 AM
ICEBOX
Jan 20, 2003 05:16 PM
