Coolant
Old Nov 23, 2008 | 04:19 PM
notso's Avatar
Coolant
What type of coolant should I use not going to flush, just add? Manual says HOAt type? Never mind found it on other post
Old Nov 23, 2008 | 05:18 PM
D-Roc's Avatar
Zerex G-05
Old Nov 23, 2008 | 07:34 PM
TexasCTD's Avatar
Zerex G-05 mixed 50/50 with Distilled water.
Old Nov 24, 2008 | 07:59 AM
BMH95's Avatar
I got Fleetguards extended life coolant for diesels. It's good for 600,000 miles, with an addative refresh at 300,000.
Old Nov 24, 2008 | 10:56 AM
Nate-03 D's Avatar
Don't mean to threadjack here but is there a link or a manual on how to go about draining/refiling the whole system? How many gallons are needed?
Old Nov 24, 2008 | 11:02 AM
BMH95's Avatar
I just put a 5 gallon bucket under the radiator drain (driver's side, a little blade **** to turn - be careful with it), with a 6 inch piece of 3/8" hose over the drain nipple. Then I drained her down. I got almost 5 gallons out (water pump leaking) then put exactly 5 back in. I opened the thermostat neck and changed the thermostat, so left that open until the motor was full of the new fluid. I then tightened up the thermostat neck and filled the radiator and overflow resivoir. Drive truck to test thermostat and fluid level, good to go.
Old Nov 24, 2008 | 11:05 AM
Nate-03 D's Avatar
Thanks. So i'm guessing that you can't get all of the old coolant out so mixing that with new stuff should be fine? Replacing the thermostat isn't needed is it?
cutthroatxxx
17
May 22, 2015 07:09 AM
fiveninefo
Sep 21, 2011 12:02 AM
Mark Hodowanec
Aug 17, 2009 11:56 AM
popeyesides
Dec 6, 2004 03:43 PM
Fillerupsonny
Oct 8, 2002 01:22 PM
