Control arms question
Old Feb 10, 2007 | 11:05 PM
C&C Milo's Avatar
Why do some lift kits advertise longer front control arms? What does the extra length get you? How do the dimensions compare to stock?
Old Feb 10, 2007 | 11:35 PM
53 willys's Avatar
the higher you lift your truck the farther the STOCK arms go down and back/closer to the rear of the front fender....causing rub
so the adjustable arms can be moved forward to compensate for that.
clear as mud?
Old Feb 11, 2007 | 10:37 AM
C&C Milo's Avatar
That makes sense. So I guess the length needed will depend on the installation.
When you move the axle forward do you need to get an extended front driveshaft?
Old Feb 11, 2007 | 10:51 AM
53 willys's Avatar
unless it is a HUGE lift, your front D-line should be just fine
Hoss
Nov 24, 2012 10:07 PM
JHew84
Jun 30, 2008 08:10 PM
Valv
Mar 21, 2005 01:41 PM
hellotbone
Nov 21, 2003 07:44 AM
hellotbone
Aug 20, 2003 12:51 PM
