Continues to Rev after letting off
When I am out of gear and rev the engine, it continues to rev for a second or so after I let off of the go pedal. Is this normal? I tried searches on here for this issue, but didn't have any luck. I have an automatic tranny if that makes a difference. Also if this requires a reflash or something, do you have to take it to a dealer or are there other shops that can do that?
I believe it is normal. If you are on the throttle heavy and let off and the fuel dropped off immediately, the pressure on the intercooler side of the turbo would be greater than the pressure on the intake side. You would "bark" the turbo often if it worked like that.
The computer brings the fuel down slowly (relatively speaking) to prevent other mechanical problems, or so I have heard. This will feel like the motor is "running away" for a second until the rpm's drop down a little.
It is a wierd feeling especially when you are accelerating from a stop and have to hit the brakes suddenly.
Dalydrvr
Jul 26, 2012 12:30 PM
Viesel
21
Feb 9, 2007 08:14 AM
Dodgezilla
Oct 9, 2006 11:10 AM
dodgediesel4x4
Dec 1, 2004 03:45 PM
4WDXPRT
Sep 8, 2004 06:43 PM
