? on compression check
Old Jun 21, 2008 | 11:47 AM
masonic-dodge's Avatar
I'm doing a compression check on my 05 right now. Does anyone know what it should be? I has 40,000 miles on it.
CRIS
Old Jun 21, 2008 | 12:36 PM
Monty's Avatar
I dont believe Cummins gives a specification for compression values. There method of checking for loss of compression is checking for excessive blowby. With so little miles, can I ask why a compression test is being run?
Old Jun 21, 2008 | 01:16 PM
I think that my head gasket is blown between 2 cylinders. I'm getting a poping from the intake and from the exhaust. The engine also has very little power.
Thanks Cris
Old Jun 21, 2008 | 02:02 PM
bigwheels94's Avatar
You should see about 350#-375#. It should jump up about 150@/ stroke for the 1st couple, & then slow down. Should get to max after about 5-7 strokes.
Old Jun 21, 2008 | 04:31 PM
Heres the compression #s 3 tests were done on each cylinder for 5 seconds each.
#1 480lbs 485lbs 475lbs
#2 475lbs 490lbs 490lbs
#3 520lbs 530lbs 535lbs
#4 520lbs 510lbs 520lbs
#5 530lbs 540lbs 520lbs
#6 515lbs 515lbs 510lbs
I just can't figure what is causing the poping and the loss of power in my engine
CRIS
Old Jun 21, 2008 | 06:57 PM
NickBeek's Avatar
Something valve related maybe? Just a thought.
Old Jun 22, 2008 | 10:35 AM
jpajax's Avatar
Could it be timing.
Old Jun 22, 2008 | 01:11 PM
no_6_oh_no's Avatar
Could still be a leak only under the higher pressures of combustion.
Have you checked low side fuel pressure, rail pressure? Rail relief valve?
Popping under hard throttle is usually a good sign the rail is draining or pressure dropping?
Old Jun 22, 2008 | 04:03 PM
Redline Ram's Avatar
Did you leave all of the injectors out while running the test to make sure its not blown between two cylinders?
Old Jun 22, 2008 | 07:56 PM
The truck is poping through the exhaust at idle
We checked the pressures with the injectors out and with them in.
As for timing I don't have a clue A great and trusted friend of mine said that the cam may be bad, so I'll have the check the lift on all the push rods.
We also checked #1 + #2 cylinders with air pressure, but nothing was coming through the valves just past the rings.
This problem is stumping me, the dealer said that they can't find anything wrong I know that there is something wrong because of the poping and the fact that the truck is a SLUG.
I really think that the gasket is blown between 2 of the cylinders, but I have no way to prove it without pulling the head.
Thanks for all your help
CRIS
Old Jun 23, 2008 | 06:59 AM
if its blown between two cylinders then if you have the injectors all out you will hear/feel air coming from the cylinder that it is blown across to from the injector hole. you may want to try a leak down tester also.
Old Jun 23, 2008 | 08:10 AM
Hvytrkmech's Avatar
One of out trucks at work has a NTC 400b/c, it was running away, smoking, and no power, I checked the exhaust manifold with my heat gun but reading were chaotic across the board, so I pulled the exhaust mainfold/turbo plugged the oil feed line and started the engine. #2 cyl not fireing at all, fuel return to tank was charging tank with compression, found a broken injector hold down bolt which in turn took the injector, injector cup, and head with it. Moral to the story, the engine ran horrible without a defined skip, it was popping and sputtering, with no power all because of the compression gasses interference with the fuel supply.
Good luck,
Tim
bgflatbed
Nov 23, 2010 10:41 AM
kingofdodge7131
Nov 24, 2003 12:16 PM
geof
Nov 16, 2003 07:20 AM
SjLingenfelter
Jun 30, 2003 01:35 PM
