compression check
Old Nov 23, 2010 | 10:25 AM
bgflatbed's Avatar
compression check
I have a question concerning checking a compression check on a 12 vlv. The reason i'm askin is the blowby has a pattern to it that matches a stutter at idle. Would this be broken rings, or burnt valve? pretty sure that a compression check would pinpoint which cylinder, but what would be the cause. Any advise would be appreciated.
Old Nov 23, 2010 | 10:41 AM
rebal's Avatar
have you replaced or had your injectors checked or cleaned?
a weak injector will through the timing off in one or more cylinders.
masonic-dodge
Jun 23, 2008 08:10 AM
kingofdodge7131
Nov 24, 2003 12:16 PM
geof
Nov 16, 2003 07:20 AM
SjLingenfelter
Jun 30, 2003 01:35 PM
