common issues with 3rd gens
Old Oct 18, 2014 | 07:38 AM
derbyboy25's Avatar
Ok guys jsut bought an 07 5.9 with 90K miles on it. newest truck i have owned or been around. With every vehicle you have "common" issues or things that typically arent up to the everyday world. What are all the common things that go wrong with these trucks? i wanna be pro active and know what to look for with things that commonly break or wear out early. thanks!
Old Oct 18, 2014 | 09:38 AM
ssandlin's Avatar
Two things come to mind....
1. Recirc door will break
2. Keep the #4 fuel injector line tight or be proactive and replace it with the upgraded line and clamp
I've done both on mine.
Old Oct 18, 2014 | 06:57 PM
pull-do's Avatar
I think the blend door is OK on the 07's, well mine has been so far. What did you have to give for that truck, just curious, kicked around selling mine, sure is a good truck though, mine has 69,000 miles.
Old Oct 19, 2014 | 12:48 AM
mykaos's Avatar
#4 injector line, replacement is less than $50.
recirc / blend more of a issue with dual climate control.
Fuel filters, use Baldwin PF7977.
If auto equipped: gut the torque converter anti drain back valve, keep fluid / filter changed regularly, use ATF+4, adjust the bands when servicing, extended periods of idling should be done in neutral.
Air filters use NAPA or WIX deep pleated.
Eventually, maybe, fan hub bearing, idler pulley and tensioner pulley bearing.
Drive it and enjoy
Old Oct 19, 2014 | 08:53 AM
kerry.king's Avatar
Hey ssandin, what's the seat mod you list in your signature?
Old Oct 19, 2014 | 09:15 AM
ssandlin's Avatar
I added foam to each, have a look here.
https://www.dieseltruckresource.com/...ight=seat+foam
Old Oct 21, 2014 | 12:37 PM
doug duncan's Avatar
my truck is stock 07 ram 2500 ctd 75250 miles on her I try to follow the scheduled maint. in the owners manual sched (b) for most trucks. so far so good.
Old Oct 22, 2014 | 08:12 PM
Shorts's Avatar
- MFS
- Coolant bypass hose
Old Oct 28, 2014 | 09:30 AM
marder's Avatar
If auto equipped: gut the torque converter anti drain back valve, keep fluid / filter changed regularly, use ATF+4, adjust the bands when servicing, extended periods of idling shouldcab be done in neutral.
Drive it and enjoy
Does 2005 autos need the tc anti drain back valve gutted? If so how does this help?
Old Oct 28, 2014 | 02:39 PM
mykaos's Avatar
"Does 2005 autos need the tc anti drain back valve gutted? If so how does this help?" .... Yes. Gutting It helps in several ways. It elimates a huge in line restriction. It also elimates the possibility of the check ball sticking in the closed position, as mine did, and cooking your transmission.
realest
Dec 23, 2010 03:51 PM
AK RAM
Aug 2, 2005 07:45 AM
AK RAM
21
Aug 1, 2005 12:16 AM
