View Poll Results: How does your truck start in the morning?
short start, sputter or loping
9.23%
short start, idles good
48
73.85%
long or average start, sputter or loping
6.15%
long or average start, idles fine
10.77%
Voters: 65. You may not vote on this poll
cold weather startup (50*to 20*)
Old Jan 14, 2009 | 04:06 PM
rip 112's Avatar
This year my truck starts a bit different in cold weather. New batteries, different turbo, fuel system or beta program could all be affecting this. What happens is the truck cranks quickly and fires off as quick as a 12 valve in cold weather, right off the start, but as soons as it cranks it sputters once then idles fine. Now when it gets colder when the 1000 rpm high idle kicks in, the truck will lope, real long lopes not like a cam, enough that you can feel it and see it move the truck back and forth. Been letting it go for awhile, but curiosity keeps eating at me. Any of ya'll go through this, or think it would be normal?
Rick
Old Jan 14, 2009 | 04:15 PM
t-boe's Avatar
It usually needs to be in the teens and not plugged in before it sputters a little, but I've never had it lope. Of course I've only got the Smarty and everything else is basically stock.
Old Jan 14, 2009 | 04:20 PM
Pooter's Avatar
Mine seems to start a little slower(when not plugged in) when the weather has been cooler (high20s to low 30s is the worst weve had so far) Its a slow crank for a second, then its fine. I have had a slightly rougher idle sometimes at a cold start(when not plugged in) just for the first few minutes(if I dont enable the high idle)
BUT my truck is pretty much stock 'cept for exhaust, air intake, smarty(revo level 3)
Ive been thinking about trying level 2 in the when its colder out, to see if taking the added timing out has any effect on the idle when cold.
Old Jan 14, 2009 | 04:27 PM
rip 112's Avatar
Yeah I don't have the adj high idle, just the one that automatically comes on when ambient temps are below 36* (for me anyway). And I don't have the plugin, so never used it to see if it would help. Coldest its got here was 24*.
Old Jan 14, 2009 | 04:57 PM
austin1972's Avatar
I plug mine in, so maybe that's why it starts up just fine. I have noticed the grid heater can make it stumble a little when it comes on. I just figured it's the instant load the heater puts on the alternator making it do that.
Old Jan 14, 2009 | 05:22 PM
Big3500's Avatar
Can you post a video of it? Sometimes when I start my truck in the cold, it will turn over slow, then fire up and be ok with just the normal stutter when the grid heaters cycle.
Old Jan 14, 2009 | 11:57 PM
dslpwr81's Avatar
[QUOTE=Big3500;2350033]Can you post a video of it? QUOTE]
x2. Lets see. RIP, my vote was for the short crank, idels fine and thats if I forget to plug it in when its -20 below out. Cranks a second longer, but not much. But, I have had it twice in 3 years to where after I start it and the high idel cranks up, it sounds like it has a moster cam. MMM MMM MMM MMM. But, it doesn't shake the truck, you can just really hear it. Don't make fun of my impression. Would also like to know why it does it.
Jason
Old Jan 15, 2009 | 06:26 AM
Valv's Avatar
Cold weather start no problem with mine. -26 this morning, wind chill -45. I didn't plug it in...
Here's video....what a truck....
http://www.youtube.com/watch?v=1DByvpmnwgE
Old Jan 15, 2009 | 09:03 AM
rip 112's Avatar
I'll try to get a vid posted asap, but this morning wasn't as cold as normal, 30 for the low but about 40* currently. Watch it start fine this morning....lol
Old Jan 15, 2009 | 09:20 AM
eights88's Avatar
what helps mine is synthetic (5w-40) makes a big difference with cold start. plug just helps with heating up
Old Jan 15, 2009 | 09:56 AM
rip 112's Avatar
Well it started up fine this morning, seems to be directed to the more cold temps like below 40*. I will catch it slippin eventually though, when I do I will get it on video.
Old Jan 15, 2009 | 07:20 PM
rip 112's Avatar
Exclamation
It started normal this morning, wasn't cold enough, but got a video anyways. Truck actually sounds good on video, you can hear that 62/71ss wheezin. I will post another video when it gets colder.
You can hear the effects of the grid heater when I idled it up a little.
http://www.youtube.com/watch?v=7FX-fVxuKLw
Old Jan 15, 2009 | 08:38 PM
xtoyz17's Avatar
As cold as 0* (low of -15 the same night) since I've owned it (2 weeks now). It started first shot on bad batteries, took about 5-10 seconds to crank, and idled a bit lopey for mayeb 5 seconds.
New batteries as of 2 nights ago, low of 0*, very quick crank and a smooth idle after 2-3 seconds.
68k miles and no previous owner info, could be wear on the cp3 or the injectors I spose.
Shawn
CTDHokie
Jun 2, 2005 03:10 PM
joel
Jan 22, 2005 08:59 PM
wings
Nov 8, 2004 05:32 PM
big red psd cc
14
Sep 1, 2004 01:39 PM
HOHN
16
Dec 17, 2003 10:38 AM
