code question
Symptom:
P0069-BOOST KEY ON RATIONALITY
When Monitored and Set Condition:
When Monitored: While the key is on.
Set Condition: The boost pressure recorded at key on is not within a calibrated range
from the inlet air pressure sensor.
POSSIBLE CAUSES
OTHER DTC’S PRESENT
INLET AIR PRESSURE SENSOR
BOOST PRESSURE SENSOR
INTERMITTENT CONDITION
TEST ACTION APPLICABILITY
1 With the DRBIIIt, read DTCs.
Are any DTC’s present for Inlet air pressure or boost pressure?
All
Yes ! Repair other DTC’s first.
No ! Go To 2
2 Using the DRBIIIt, compare the inlet air pressure (barometric pressure) sensor
reading to the boost pressure sensor reading.
Are the pressure readings within 6 in hg of each other?
All
Yes ! Test Complete.
No ! Go To 3
3 Turn the ignition off.
Install Miller special tool #9022.
Ignition on, engine not running.
Use the DRBIIIt and compare boost pressure reading to the regulated air pressure
for tool #9022.
NOTE: The reading on the boost pressure sensor may be slightly lower than
the regulated pressure.
Does the boost pressure sensor reading increase with the regulated air pressure?
All
Yes ! Replace the Inlet Air Pressure sensor.
No ! Relace the Boost pressure sensor.
52
DRIVEABILITY - DIESEL
POSSIBLE CAUSES
OTHER DTC’S PRESENT
All
No ! Go To 2
All
No ! Go To 3
for tool #9022.
All
52
Basically, when you first key-ON, ECM reads the MAP and Baro sensors, comparing their output at Barometric pressure, which must match in order to accurately control fuel and Boost - one or the other is incorrect, which can be seen with the DRBIII or a scantool - if none available, it's just replace one - if that doesn't fix it, replace the other - OR: swap with a buddy's truck to find the bad one - his truck will give P0069 when the bad sensor is plugged into his truck - and, if you hurriedly drive away, yours is fixed, eh?
O.T
Sep 6, 2007 06:10 PM
CTD NUT
Apr 5, 2005 04:45 PM
