Code P2026
Code P2606
My buddy's 2006 G-56 CTD lit the check engine light but it has since gone away. The code 'P2606' was retrieved. Any one got an idea of what caused it to shoot this code? By the way it was 15-20 below zero when this happened and 20 above when he drove it today and the CEL went off right away..... don't know if the temps had anything to do with it or not? Any ideas?
As to your question of why, is it possible that the filter monitor provides this code and it's spring is weak? Some have posted that their turbo will pull it into the yellow or more on WOT even with a new filter. And there could be a minor fault also. Check and/or reset the monitor and then run it at WOT and see if it moves (its a latching mechanism).
All in all, I don't think you have any serious issues.
Cya
Cya
O.T
Sep 6, 2007 06:10 PM
CTD NUT
Apr 5, 2005 04:45 PM
