Code Help
Old Jan 14, 2008 | 04:09 PM
coyle2285's Avatar
Code Help
I have had a hard time starting this truck and now its to the point where it wont start at all. I did the key cycle 3 times and came up with P2607 and P0541. Not sure what is going on but hate not being able to start the truck at all. Maybe someone can help me figure out what my problem is. Thanks
Old Jan 14, 2008 | 04:25 PM
sweeney186's Avatar
Low voltage at heater grid relays(#1,#2) are your codes.Very doubtfull that your no start prob.A no start w/ no codes usually involves a fuel press prob.-lift pump inop or inj w/ excess bleedback,blown overflow valve-etc.
Old Jan 14, 2008 | 04:46 PM
coyle2285's Avatar
how can i check the fuel pressure? Also what do i need to have to check it and what should it read at idle?
Old Jan 14, 2008 | 09:54 PM
sweeney186's Avatar
Since it does not run,I would imagine your talking about cranking.You should be reading around 10 psi on your outlook monitor.If you've got press-its going to take some special tools to figure the rest out-mostly dealer items
Old Jan 15, 2008 | 08:48 AM
coyle2285's Avatar
well the monitor is on my 05 truck and it runs good, its the 03 that is having the problems now. I think i may have bad injector or injectors becuase im hearing a little rattle as im going down the road and i remember having number 4 replaced because of trash clogging it up, so i might have more that need to be replaced.
Old Jan 15, 2008 | 12:10 PM
sweeney186's Avatar
If you've had inj issues already-yes you prob need at least one more
Old Jan 15, 2008 | 12:23 PM
cwoodall's Avatar
Most likely on the '03. My '03 is giving me heartburn as well........very common.
coope3
Feb 21, 2009 04:49 PM
kenny1987
Jan 24, 2008 01:19 PM
O.T
Sep 6, 2007 06:10 PM
Terraizer
Dec 14, 2005 03:56 PM
CTD NUT
Apr 5, 2005 04:45 PM
