clutch slipping at 30k??
Old Apr 29, 2009 | 10:57 AM
supersonictoys's Avatar
I noticed the other day while on a slight freeway incline towing 15k that if I floored my truck in 6th gear, once I reached about 2000 rpms the tachometer would jump up to about 2300 for a few seconds and then drop back down to about 2100 and then go ahead and slowly accelerate normally. its like when it really got into the power "sweet spot" it slipped. I could even hear the motor rev higher when it did it. is this at all normal? I only have 30k on the truck and am not a "hot rodder" and know how to drive a stick. that's all I have ever had. anyone else who tows ever had one slip a bit like this??
Old Apr 29, 2009 | 11:29 AM
Spooler's Avatar
What year is your truck? Do you have the G56 tranny with dual mass flywheel. If so this would be why. I would keep driving it and downshift if you have to romp on it again.
Old Apr 29, 2009 | 08:18 PM
NickBeek's Avatar
Nope not normal. Does it happen to people with the G56 yes it does. Dodge will not warranty it either.
Old Apr 29, 2009 | 09:57 PM
Fisherguy's Avatar
You running any mods? Mine only did that when I cranked up my Bully Dog, have since put in a stronger one.
Old Apr 30, 2009 | 12:29 AM
well its a bone stock 06 with a 50hp chip. I think its the g56. why would the clutch be more prone to slip with the g56?? and what's a dual mass fly wheel?
Old Apr 30, 2009 | 01:28 AM
PRO-NRA's Avatar
Anything over stock will slip the clutch. Mine is still stock clutch with the infamous DMF. I slips empty on 3rd going up the freeway ramp if I'm agressive on the skinny pedal and I only have 19K miles on it. Go with SB DD and not wory about it.
Old Apr 30, 2009 | 07:26 AM
Fisherguy's Avatar
The DMF is a weird looking thing. It's got like springs or something in it to help absorb some of the vibrations. When you do the clutch you'll get a new solid one and you'll hear a little more gear noise from the tranny when you're driving, it'll sound like you left the boot off.
I like the SB OFE, feels like stock without the DD noise and slower shifting.
Old Apr 30, 2009 | 10:13 AM
tool's Avatar
Strange.
I have 91,000 on my stock original clutch and have grossed over 30,000# towing with it.
I have tried to be very nice to the clutch, although I have been stuck a few times loaded and likely abused it a little.
I have noticed lately that it is starting to get a bit grabby when feathering it backing up loaded.
Mind you my truck is BONE stock.
I wanted a Smary but decided to wait until the original clutch is shot to get as much life out of it as possible.
I don't have anything bad to say about the stock clutch or the G56 setup.
Old Apr 30, 2009 | 10:20 AM
Slurryboss's Avatar
I have 86k on mine with the mods I've got, and it is just starting to slip. I'm going to Floor It in Lawrence, KS next week to get the southbend DD 3250. I hope this will be a good solution for my needs. I'll let you know how it all turns out.
1stTimeAround
Sep 5, 2006 04:15 PM
csramsey640
Jul 5, 2006 10:31 PM
hovisimo
Oct 10, 2005 04:43 AM
chrismez
Jan 4, 2005 06:12 PM
Lightman
35
Dec 2, 2004 08:34 PM
