Clutch rattling?
Old Apr 10, 2011 | 12:26 PM
dodgeman5902's Avatar
Clutch rattling?
Hello can someone Please help me? Me and my son just finished installing a new
SouthBend Dyna Max Clutch kit(1947 CON OFE) with flywheel.When we first started the truck the was like a rattling and the clutch pedal seems too soft.
We drove the truck but could not hear the rattling anymore, when we got back home we could hear the rattling again. Does anybody have any ideas on weath
er this is normal or not
Old Apr 10, 2011 | 01:19 PM
swivel5309's Avatar
i installed a southbend clutch with their throwout bearing and it rattles like crazy! Ive heard SB had a run of bad bearings! "put me on a major bummer" but the clutch works great! the rattle go's away when I push in the pedal
Old Apr 10, 2011 | 01:42 PM
did you have to install a new throw out bearing??? Mine goes away too when I push in the clutch.
Old Apr 10, 2011 | 02:26 PM
Derek Timm's Avatar
Did the clutch disc have metal springs or synthetic solid springs? I had the solid synthetic springs and they ratteled like crazy at an idle. Southbend sent a new clutch disc with a LUK hub with real srpings and it helped a lot.
Don't expect these to be quite or smooth like the factory units. Especially if you replaced a dual mass unit.
Old Apr 11, 2011 | 02:33 AM
swivel5309's Avatar
I put the bearing in while it was apart! it came with the clutch! Why not? Rattlerattlerattle! at least its new!
Old Apr 11, 2011 | 04:10 PM
Roperteacher's Avatar
I had a new Valair installed last fall on my 2007 5.9 and it does the same, rattles like all get out. As soon as clutch goes in, it goes away. WOrks great. I called and they said to push the throttle to 1,000 rpm. If it went quiet it was fine. And it does exactly that! Hope it helps!
Old Apr 11, 2011 | 04:42 PM
swivel5309's Avatar
sure.... they cant hear it!
Old Apr 12, 2011 | 09:02 AM
texastuff's Avatar
we should blaim chrysler for building a aluminum case tranny using atf. all solid flywheel conversions make more noise
Old Apr 12, 2011 | 03:45 PM
swivel5309's Avatar
my nv5600 it cast iron!
apwatson50
Jan 5, 2005 02:41 AM
DawgII
Oct 28, 2003 07:11 AM
jsr21
Jul 16, 2003 02:16 PM
mymaur
Jun 20, 2003 01:14 AM
MJR
Mar 16, 2003 08:26 PM
