FWD shifter rattling
Old Dec 26, 2004 | 07:38 PM
apwatson50's Avatar
My FWD shifter rattles and makes a bunch of noise going down the high way in 2wd, and going up my driveway in 4wd, basically all the time. Does anybody else have this problem and/or have a fix?
Thanks, Aaron
Old Dec 26, 2004 | 07:51 PM
caleb c.'s Avatar
Lots of guys recomend to spray down the linkage with a good spray lube.When my truck was doing that a few years ago it was the rear U-joint.I replaced and it all went away.Just something to remember if the oil trick doesnt work.
Old Dec 26, 2004 | 08:55 PM
jiMMyCTD's Avatar
the linkage is probably loose under the truck. jiMMy
Old Dec 26, 2004 | 09:24 PM
sammy340's Avatar
My shifter does this too when accelerating at certain speeds. What U-joint was it that you replaced caleb? The rear one right at the diff?
thanks
jeff
Old Dec 26, 2004 | 10:29 PM
caleb c.'s Avatar
Yes sir,thats the one.It completley cured it.
Old Dec 27, 2004 | 09:14 AM
Nuttymopar's Avatar
Also people have replaced some of the spacers in the 4wd shifter with rubber spacers or nylon to stop the rattle noise. I just place a glove over the handle and it keeps it quiet. Cheaper that way.
Old Dec 28, 2004 | 09:39 AM
vinny's Avatar
My little nylon washers were all wore out...
I took it apart,greased the heck out of the whole thing,and replaced the washers with some thin rubber 'o' rings.
That was 6 months ago or so,and it's still nice and quiet.
Vinny
Old Dec 28, 2004 | 11:40 AM
andyr354's Avatar
So far I have gone lowtech and have a little 3" bunje cord hooked under the front lip of the metal boot holder and then to the top of the shifter.
Stops all the rattles for me, gotta whole pack of them at the hardware store for a couple of bucks.
Old Dec 31, 2004 | 10:15 PM
jive55's Avatar
What have you found out ? I don't want to scare you but if none of the things the guys have already mentioned has worked. Let me know. I'll tell you what my did.
Old Jan 2, 2005 | 07:41 AM
Chrisreyn's Avatar
there wa another thread about this awhile back and someone recommended putting a length of garden hose over the linkage to stop teh rattle. I did it and its been nice and quite for a few months now.
Old Jan 2, 2005 | 07:46 PM
CrewCabCummins's Avatar
Yep.. I put that garden hose on there about 3 years ago and ALL the noise has been gone ever since... but remember...when "that noise" is gone , your just hear something else
Old Jan 3, 2005 | 08:02 PM
apwatson50's Avatar
I haven't tried anything yet, but I am going to do the garden hose thing and the oring thing sometime this week.
By the way according to the local dodge dealer those nylon bushings have been discontinued.
Old Jan 3, 2005 | 09:55 PM
mhuppertz's Avatar
Be careful about using a bungee to apply pressure on the shifter. You have wear out the shifting fork.
A welding glove is a great fix for the normal rattle.
I used to have a '77 Macho Power Wagon that rattled like a mother, but after spending $750 on all new drivelines the rattle vanished for good. In fact the trucks max speed went up!
If I have the jack, I would replace the drivelines on my '93 right away!
Mark
Old Jan 4, 2005 | 10:02 PM
apwatson50's Avatar
Good news, I cut a piece of rubber and put in between the shifter and the inside nylon bushing, and I put heater hose on the shift rod, and no rattle!! so far.
Old Jan 5, 2005 | 02:41 AM
Bushy's Avatar
Patron Saint of 1st gens
Just a couple thoughts on this one.......
The 4wd shifter gate assembly has a nylon looking, square corner horseshoe that fits over one of the gates. The nylon "bushing" is about 1" long as I recall and is located directly behind the moving part that runs in the shifter gate grooves.
You'll have to look REAL close to see it but it's there..
On mine, this "bushing" began to wear a bit more in one spot and less in the other so what Id did was to remove the bushing and swap ends then re-install it.
So far I have had no more rattling.
As an aside I think DC has a replacement for it. (At least there was a few years back.
I think my brother may have installed a new one on his truck. I'll ask him about this and see if he has any part(s) numbers for you.
pb....
sdubfid
Dec 7, 2008 01:08 PM
AndyS
Feb 24, 2007 09:49 PM
TurboCrisco
Jan 15, 2007 09:23 PM
Dieseldirt
Oct 3, 2006 07:16 AM
Ridiculous
Mar 26, 2006 09:51 PM
