Clutch Hydrolics Question
Old Jun 28, 2010 | 12:23 AM
jmlcolorado's Avatar
Question Clutch Hydrolics Question
So my master cylinder on the clutch has been going out for quite some time now. I used to have to filll it up about once a month to keep the clutch working good. Now im having to fill it once a day.
Now i thought i had heard that you have to buy the entire assembaly from the master to the line and the slave as it was one sealed unit but im seeing the master cylinder ONLY being sold:
http://cgi.ebay.com/ebaymotors/Sachs...item3a5c446323
Can i just buy the master cylinder only to replace?
Thanks guys
Old Jun 28, 2010 | 10:08 AM
Anyone?
Old Jun 28, 2010 | 10:45 AM
rich's Avatar
probably be easier and better to buy both that way you know there both new and strong.
Old Jun 28, 2010 | 04:53 PM
Colo_River_Ram's Avatar
With age comes the cage
Get the new updated HD combo..do a google for online sales
Old Sep 5, 2010 | 06:44 PM
JHardwick's Avatar
I just bought one the other day from Mopar. The master cylinder, line and slave cylinder is all one sealed unit. Which I had a feeling, because there is no bleeder on the slave cylinder.
NOW, how do you get the rod off of the pedal arm?
Old Sep 5, 2010 | 09:29 PM
There is a white plastic joint at the end of the pedal shaft. You have to press a number of small flanges to "unlock" around the dome shaped pin then press it out towards kick panel.
At first, i didnt see how i could do it without breaking it but somehow i did just by using a good pair of needle nose.
Make sure when you reinstall the pin, add some heavy grease to it. I didnt do that and now i have a squeek when i depress the clutch.
Good luck.
FYI, the system from mopar is a sealed system. As tempting as it seems to reinstall everything, DONT try to seperate in two pieces. It will never work right.
Old Sep 9, 2010 | 11:01 PM
stickk's Avatar
Broke the little plastic keeper when I changed the clutch. Got one from dealer and it broke while installing rod onto pedal. Zip tie has been on for 30k and still holding.
65fury
Jul 21, 2011 12:37 AM
Torqueanhps
Apr 2, 2010 02:31 PM
cody_d
Jun 11, 2009 12:35 AM
cody_d
Jun 8, 2009 11:00 PM
