Clutch is gone
Old Apr 4, 2011 | 09:06 AM
y22man's Avatar
Clutch is gone
Hello All,
My clutch went out this morning at 40701 miles. sigh
Is there a good shop in SLC I can take it?
I aslo want to call around and see what the prices are to put in a South Bend in. Do you know some shops for this swap?
I am wondering if since the tranny is out, if I should get the taller 6th gear in the later model.
Old Apr 4, 2011 | 06:38 PM
y22man's Avatar
Any imput about 6th gear? I know others have done it.
Old Apr 4, 2011 | 08:36 PM
DodgeChallenger's Avatar
You can get a taller 6th gear?????? What is the ratio compared to stock and where is it available?
Old Apr 4, 2011 | 09:44 PM
rockcrawler304's Avatar
I don't remember the ratio but IIRC it is in the 07.5 and up G-56's.
To the OP... if you can do it I say go for it. I would and probably will when I do my clutch.
Old Apr 6, 2011 | 01:54 PM
y22man's Avatar
I don't remember what the differnt number is but I know I have the first generation G56 that has the .74 in it instead of the .79. Those numbers could be reversed. But it gains you something like 200 RPM in 6th.
Old Apr 6, 2011 | 07:28 PM
cletus's Avatar
Is it a big job to change 6th gear.
Old Apr 6, 2011 | 08:46 PM
Danderson's Avatar
I went to 285-75-17's. Good compromise.
Old Apr 7, 2011 | 08:59 PM
y22man's Avatar
I can not find the posts, or I read it on tdr. I do not have a login to tdr. I might pay for one to get the info. I do not know if it is easy or not.
Old Apr 7, 2011 | 09:41 PM
Not all the info but here is some talk of the .74 taller gear for the G56
https://www.dieseltruckresource.com/...&highlight=.74
Old Apr 15, 2011 | 03:50 PM
y22man's Avatar
I am going to go with south bend. Now which one? I will eventually get a smarty jr. But that is it. Which version of south bend should I get? I think the con ofe will be over kill. Only looking for opinions.
Old Apr 15, 2011 | 09:13 PM
bigblue1ton's Avatar
what kind of drag racing or tractor pulling do you do to lose a clutch at 40k
Old Apr 16, 2011 | 10:15 AM
y22man's Avatar
none, same driving as my 94 that has the original clutch and has 171,000 miles on it.
I pull a 5er about 10 times a year and 6000lb boat about 20 times. It comutes to work.
But thanks for your constructive comments on the thead.
Old Apr 16, 2011 | 10:31 AM
johnh's Avatar
Hello All,
six states did mine........
Old Apr 17, 2011 | 07:13 PM
LOWTYD's Avatar
I assume you truck is stock. Put on a set of 35's and reap the rewards on fuel mileage and lower interstate towing RPM's. I cant imagine the cost to change out 6th gear. My truck currently has 170,000 with stock clutch and mild power adders. Towed my 6k pound boat from coast to coast about 4 months ago with no issues. I can slip the clutch at will, but I've learned to drive it so it doesn't slip. My next upgrade will be a Southbend clutch , but still not sure which one. Good luck. BTW, can you make it through gaurdsman's pass yet? It's a beautiful drive....
arroyojim
48
Sep 9, 2016 09:43 AM
cbrahs
Nov 1, 2011 11:00 AM
TAMU
May 27, 2009 06:34 PM
TAMU
Apr 27, 2009 11:26 AM
3500Dooly
23
Jun 8, 2006 10:21 PM
