Clutch fan
Old Jun 17, 2009 | 05:19 PM
sjjjojjj's Avatar
Clutch fan
Hey guys, wondering if anyone could tell me how to test my clutch fan to see if it working properly. when towing I have high temps up to 215 - 220 even if Im not in the pedal. New thermostat didn't help and rad is clean. My trailer is about 9500lbs I pulled it in the mountains last year with no issue. Any input would be greatly appreciated.
Old Jun 17, 2009 | 05:31 PM
dodge35000's Avatar
The fan clutch should engage when the air conditioning is turned on. You can also check your trouble codes for the insufficient fan speed code.
Old Jun 18, 2009 | 01:33 PM
GreyTD's Avatar
Another way is, with the truck at operating temp, ground pin 1 on connector bottom of shroud. rev to 2000rpms you should hear the fan start to roar within a min or 2. This will set a code DTC 0480.
FamilyDiesel
Mar 30, 2008 05:53 AM
jrs_dodge_diesel
Sep 28, 2007 11:38 AM
MmmDieselFumes
Sep 27, 2007 06:44 PM
MmmDieselFumes
Sep 27, 2007 03:04 PM
big jimmy
Jul 7, 2006 01:33 PM
