Clutch engagement problems
Old Jan 3, 2009 | 01:26 PM
6-Pack's Avatar
Lately I've been having some problems with my clutch. Most of the time it works fine, maybe just a little harder to get in gear than I'd like, but not real bad. Occaisionally though, I'll be stopped with the clutch in, in second gear and when I go to release it, it starts grabbing almost instantly. Try to pull it out of gear with the clutch in and you have to really force it. Not a good feeling. Put it in neutral, pump it a couple of times and back to normal. Not a constant problem, just once in a while. But way too often for me. OFE is only about a year old, clutch cylinder is full, no leaks that I can see. Any ideas?
Old Jan 3, 2009 | 02:23 PM
dozer12216's Avatar
Replace the cluch slave and master assy as a assembly and be done with it.
The Dodge part # was near 150 last time I checked and one from Southbend clutch was slightly higher. The SB has a slightly better Mechancial advantage for higher pressure clutch covers, as I understand. JMHO
Old Jan 4, 2009 | 10:22 PM
buralcat's Avatar
slave for sure same thing happened to me 6 months ago. you probably don't have to long till it goes out, mine gave me about a months worth of notice.
dieselfreak21
Jul 13, 2010 09:55 PM
dieselfreak21
Jul 9, 2010 03:11 PM
DennisT
13
May 8, 2007 06:19 AM
Ph4tty
Apr 9, 2006 10:39 AM
hotwheels
Mar 9, 2004 09:45 AM
