Clunk noise from rearend
Old Jul 13, 2004 | 06:58 AM
angleiron's Avatar
I have 18K on the truck, and I do not tow that much. I am starting to get a loud clunk from the rear end when the tranny up and down shifts. It does not happen all of the time, so is this a problem that is known?
Old Jul 13, 2004 | 09:59 AM
DAYTRIPPER63's Avatar
Check your Exhaust
Mine did same thing and it was exhaust hitting
Old Jul 13, 2004 | 12:11 PM
AK RAM's Avatar
Originally posted by DAYTRIPPER63
Check your Exhaust
Interesting. Never thought of that. Mine goes to the dealer tonight for the same thing. I figured U-joints as a result of consistent bursts @ 900 ft lbs of torque. Where was your exhaust hitting?
Old Jul 14, 2004 | 06:09 AM
angleiron's Avatar
This does not sound like the exhaust hitting anything (what would it be hitting anyway?). It sounds pretty close to a u-joint, beacse even in traffic and going from 1st to 2nd at a slow speed it happens at the same time the tranny shifts...no delays.
Old Jul 14, 2004 | 10:03 AM
doitl8r's Avatar
My 2003 CTD does the same thing....only in stop and go trffic when the tranny shifts from first to second and you let your foot off the gas to stop. The 2500 never gets above 10-15 miles per hour.
Anyone else??
Old Jul 14, 2004 | 10:14 AM
nickleinonen's Avatar
my exhaust was hitting on my truck. the clamp before the muffler was just touching the crossmember when the engine torqued. i have a little bit of a clunk in my driveline but last time i was under there, the u-joints were ok, it looks like the clunk was the rear diff pinion backlash. might be a little high, but i'll see when i change the rear diff oil and look at the pattern on the gears. if it looks good, i'll leave it as is... if it doesn't look good, then to the dealer i shall go with it. [hoping for the first one though, it doesn't really bother me]
Old Jul 14, 2004 | 07:53 PM
AK RAM's Avatar
Anyone else??
Exact same thing. I mainly hear it when slowing down, just before full stop. Nice loud "clunk."
Old Jul 14, 2004 | 11:53 PM
TWK's Avatar
TWK
I have a 2004 Dodge Cummins1 ton single wheel with a 6 speed and the clunk is terribly annoying to me. The dealer said that was normal. I asked him why didn’t the last 10 Dodge trucks that I had both in diesel and gas didn’t do it. Of course his reply was that they made some improvements. In short they would not admit that there is a problem. This was my 1st service so I will just bring it up again at the next oil change. Oh, they had to add oil to the rear differential as it was not filled from the factory and not caught during the PDI.
And the lousy paint is another matter.
TK
Old Jul 15, 2004 | 12:49 AM
AK RAM's Avatar
Picked up the truck from the dealer this afternoon and as expected, dealer said it was normal. Said it is the result of stopping too fast as there is a lot of tension in the driveline when the tranny comes out of gear with a sudden stop. He said if I stop less aggressively it doesn't happen.
Well, he is right. It doesn't happen when I stop less aggressively, but that doesn't mean it is normal. I too will just keep an eye on it and bring it up when/if I ever have to go back again.
On the bright side, they ordered two weighted power steering hoses to take care of my steering wheel vibe that I didn't know I had. Service manager said I had some vibes going on when he drove it and he wanted to take care of that for me. I asked him if he was feeling OK.
Cummins610
17
May 29, 2010 12:50 AM
Fishinghaoliboy
Jan 25, 2009 09:10 AM
65fury
Apr 1, 2008 08:57 PM
MasseyMan1089
May 23, 2007 07:56 PM
dpeder
Feb 21, 2006 11:34 AM
