Clicking And Popping From Front End While In 4wd
Old Mar 20, 2009 | 02:39 PM
One Way's Avatar
I have recently been hearing a clicking and popping noise from the front end of my truck when in 4wd, but, only while turning the wheel and moving. No noise while driving straight in 4wd, and no noise while turning in 2wd. I am pretty sure it is not the axle end u-joints since they were recently replaced and I know what to listen for with that. Could this be my front drive shaft joints? Truck has 150K and still has original joints in front axle driveshaft (ie the shaft from the transfer case to the pumpkin). Anyone with similar noise, and what was the problem/solution? Just having a hard time understanding how the front drive shaft (since it is always spinning) could make noise when just turning and not all the time if it was bad, explanation???? Much appreciation for any help.
Old Mar 20, 2009 | 03:38 PM
j-fox's Avatar
On dry pavement?
I hope you know it is BAD to drive in 4X4 on dry pavement.
Old Mar 20, 2009 | 04:38 PM
One Way's Avatar
Seriously? No, not on dry pavement.
Old Mar 20, 2009 | 11:04 PM
txarrowhunter's Avatar
you can probably see them and check them out with a light. just turn your wheel sharp.
Old Mar 21, 2009 | 12:48 AM
One Way's Avatar
What are you talking about (txarrowhunter)??? see what??? gremlins????? Someone out there has to have a similar experience. I thought that I would get a little info before investigating myself to save myself a little time.
Old Mar 21, 2009 | 06:05 AM
JP-4.5's Avatar
Sounds like axle u-joints... If you look at the axle u-joints you may see rust, metal or some indication that they are bad.. Have a friend turn the wheel and see what happens...
Old Mar 21, 2009 | 07:06 AM
ptm600's Avatar
Just turn the front drive shaft back and forth while looking at your axle u-joints. You'll see slop in them if they're bad. Any slop at all and they need replaced. If you can hear clicking, they are pobably bad.
Old Mar 21, 2009 | 12:14 PM
Yeah if gremlins was what you where talking about in the first place.
Old Mar 21, 2009 | 10:35 PM
One Way's Avatar
Still the question remains, if it's the axle u-joints, why not any noise when not in 4wd, I guess no load? Also, the sound this time is nothing like last time. Will check them out manana, just not too happy that I might only get 50k out of this set, last set I got 100k.
Old Mar 21, 2009 | 10:48 PM
mr-walleye's Avatar
I too have click and crunch sounds ,been all through front-end checking and found all ball joints loose with only up and down movement.Priced lifetime ones $550.00 (purchase only)
Old Mar 22, 2009 | 11:08 PM
One Way's Avatar
Yep, got the rust oozing, looks like new u-joints again, will definately get the tork-king greasables, since the main failure seems to just be contamination of the needle bearings, might as well do the Carli upper ball joints while I am at it.
Old Mar 27, 2009 | 10:55 AM
boyce's Avatar
I had a click pop on tight turns and especially offroad in 4wd. It was a bad front axle ujoint......
Dealer charges anywhere from 320-500 to change both depending on where you go and what kind of ujoints you purchase. Or DIY for $120-200
Old Mar 30, 2009 | 09:12 AM
saggonwaggon91's Avatar
the reason you only hear it in 4 wheel drive is that is the only time power is being applied to the front axle, when not engaged it all just free-spins
Buela
Sep 12, 2015 11:08 PM
joem
Jun 22, 2011 07:36 PM
RonP
Jan 28, 2010 08:30 PM
tx4x4er
Oct 22, 2006 01:44 PM
052500#1
Jan 11, 2005 04:09 PM
