Clicking felt in Steering wheel and gas pedal
I feel a clicking in the steering wheel like something is loose. The dealer says he does not feel anything. Does anyone else have this? Sometimes I can feel it in the gas pedal as well.
Jeff
2006 Ram 2500 67k
Jeff
2006 Ram 2500 67k
I've got the same clicking that you're referring to. Can be felt through the wheel. When my truck was under warranty, I got the same response from the dealer. I've learned to live with it, but I am curious to know what it is.
I've had the same problem for awhile now. I think I've narrowed it down to the driver side wheel bearing/hub assembly on mine. I took it up to a friend of mine's shop thinking it might be ball joints, and it wasn't. Found out the wheel bearings on the driver side have some slack up and down, and side to side. So ordering the hub assembly next week, and hopefully that will fix it. We'll see
You guys might try having somebody turn your steering wheel back and forth with the engine running, while you look under the front of the truck at the driver side track bar mount. It may be "wallowing" out. It is a common problem on our trucks. I know mine had a "popping" sound due to that.
Lazarsmith sells the "Ultimate Track Bar Hardware Kit" which will fix it.
http://www.lazarsmith.com/SSSSS.html
The clicking that you are refering to may be the front axle u-joints.
You can easily check them by turning the front driveshaft back and forth and looking for movement in the u-joint located at the steering knuckle.
Mine popped while turning the wheel and you could feel it through the wheel and floor. Took it in and was a tie rod end. Sounded like it was a fairly common occurance because the tie rod ends are sealed and non greasable but are prone to leaking which allows water in and seizes them up due to lack of grease. Mine did it worse when I hit a bump while turning. Was not loose rater seised up. My mechanic (which I trust) said there was nothing he could find origially when I took it in but after having him drive it for a day he found the tie rod end. Maybe thats why the dealer cant find the problem....or they dont want to find it.
vang1111
13
May 14, 2012 11:55 PM
silverbullet02
Oct 5, 2009 12:16 PM
steelydan
Jun 8, 2004 08:52 PM
Silverram03
Jun 25, 2003 10:17 AM
