cleaning engine and compartment
Old Jun 27, 2007 | 02:26 PM
Delectric's Avatar
I used to be finatical about a clean engine on my gas engines but since I switched to the cummins I haven't washed it. I am a little worried about blasting water around the engine becuase I just don't know if anything can be harmed. I do see truckers washing their engines down all the time, so is it safe? If a gas engine didn't start after hosing off I knew what to look for but not on the Diesel.
Old Jun 27, 2007 | 06:00 PM
Mike_Boutet's Avatar
Shampoo it just like you did with the gas motor.Just dont shoot the water into the alternator or directly at the wiring harness plugs. A clean motor is a happy motor.
Old Jun 29, 2007 | 09:38 PM
Delectric's Avatar
Thanks Mike!
Old Jun 29, 2007 | 10:38 PM
Festus's Avatar
I've used a pressure washer on mine four times already. Even on my '98 gasser. You just can't stick the nozzle 6 inches away is all.
foxtrot
May 14, 2011 03:21 PM
EverydayDiesel
19
Aug 2, 2007 05:36 PM
MK4288
Jun 22, 2004 11:38 AM
