Check out this balljoint
Old Jun 21, 2008 | 07:58 PM
Dan_K's Avatar
I just did my 15k maintenance and switched it over to synthetic 5w40 rotella.
Take a look at my driver side ball joint and tell me if I have a problem or not, looks like some seepage so what does that mean.
Also the manual says to lube front door shafts, what does that mean??
thanks,
DK
Old Jun 21, 2008 | 08:14 PM
bluechrome's Avatar
Thats your U-joint!!
Old Jun 21, 2008 | 08:25 PM
Dan_K's Avatar
O.K. U-joint, so are we looking at a problem or are we cool???
Old Jun 21, 2008 | 08:43 PM
BroncoAZ's Avatar
You're cool, the u-joints are always a bit greasy. Servicable u-joints ooze grease out of the caps when you service them.
Old Jun 21, 2008 | 09:10 PM
Dwitt0187's Avatar
thoughs are seal ujoints and should not be wet the are prolly on there way out if it was greasable it would be ok but it is the stock ujoint and should be dry on the outside
Old Jun 21, 2008 | 09:40 PM
Kman9090's Avatar
Yup shouldn't be grease leaking out, sound slike your seal went out and now there will be no grease in them. I'd say you'd get another 10,000 out of them before they completely go out maybe more maybe less.
Old Jun 21, 2008 | 11:45 PM
OOPS's Avatar
The pins on the hinges for the doors.
Old Jun 22, 2008 | 12:30 AM
Dan_K's Avatar
It's only the drivers side that is saturated. It's too bad there wasn't a way to retro a grease fitting. I guess I'll take it in under warranty.
GreyTD
14
Dec 24, 2007 09:13 PM
wreedCTD
Sep 8, 2007 08:48 AM
B-MAN
May 22, 2007 06:35 PM
Geico266
14
Jun 6, 2005 09:21 PM
AlpineRAM
Oct 13, 2004 06:05 PM
