Change axle fluid instructions?
Old Jul 25, 2008 | 02:22 PM
estesbubba's Avatar
I found the instructions here for the fuel filter but haven't found any for the front and rear axles. Does anyone have a link to instructions for this? If not, what is the general procedure?
Old Jul 25, 2008 | 02:39 PM
OOPS's Avatar
Place drain pan under diff.
Start removing bolts from the bottom up. Only loosen the top bolts a few turns.
Slowly pull on the bottom of the cover to let lube out.
When the majority of the lube is out remove the top bolts and take cover off.
I then clean everything up with brake cleaner and wipe it down.
Let it air out for 5-10 minutes for the brake cleaner to evaporate.
Replace the cover and bolts, no new gasket is needed.
Tighten the bolts in a cross pattern working your way around the cover. Be easy, they will break if you tighten them to the recommend torque in the FSM.
Fill with fluid.
Old Jul 25, 2008 | 04:34 PM
snoyes's Avatar
First step I would have is to clean off the exterior of the diffs before doing anything. Great story on here is a guy that didn't do that, and of course, got sand in his diffs. Spent hours cleaning it out...
james1
Sep 15, 2008 05:14 PM
icrider
31
Jan 2, 2007 04:46 PM
HorseHauler
56
Oct 31, 2006 01:02 PM
Mike S
Jan 12, 2005 08:47 AM
Idaho Guy
Apr 20, 2004 09:15 PM
