Trace= Less than .5%?
Old Jul 23, 2008 | 04:38 PM
Roperteacher's Avatar
I just got back my OUA on my truck. THis time I had a "Trace" of fuel. I called blackstone and they said Trace is usually just under .5%. Normally I have readings of LESS than .5% and once I had a .5% exactly. Is this what others are usually seeing?
Old Jul 23, 2008 | 05:03 PM
D-Roc's Avatar
Blackstone maintains that anything less than 2% is "within limits" You're fine.
Old Jul 23, 2008 | 05:29 PM
Thanks D-Roc Wonder what would cause a trace? Who knows, not going to worry.
Old Jul 23, 2008 | 06:49 PM
OOPS's Avatar
Because all of the fuel charge that is in the cylinder does not burn and does not get pushed out the exhaust. Pistons rings are not a complete seal, after all they are a split ring with a small gap.
Old Jul 23, 2008 | 08:47 PM
Thanks for the help.. I won't worry about a trace...
Old Jul 24, 2008 | 02:56 PM
zuki_dan's Avatar
I got a sample back before that had a trace of coolant. When I called for an explantion they said it was like having one drop of coolant in 55 gal. of oil. They told me not to be alarmed.
Old Jul 25, 2008 | 01:06 PM
05mxdiesel's Avatar
Did you take the sample cold or after a short drive? When I was a newb to UOA I wanted to sample one of my bikes. I rode it around the yard to warm the oil up and to get it circulating. That sample came back with 3% fuel but everything else was in check. Even though it was a carbed bike with not so great fuel delivery, I make sure I take samples after a long drive to get everything up to temp and burnt off.
Old Jul 25, 2008 | 07:18 PM
Hvytrkmech's Avatar
Probably from idling and running your air conditioning, it's called wet stacking and at a trace level it is simply no concern what so ever.
Tim
Old Jul 25, 2008 | 09:08 PM
I had actually towed with the truck all day and only let it cool an hour before I took the sample. When I called they did say it was pretty much undetectable. LOLOL
jmccart
Jul 17, 2008 10:05 AM
Sask
Aug 5, 2006 12:59 PM
wexman
Jan 1, 2005 10:02 AM
Jun 15, 2003 02:10 AM
Jim O
Oct 29, 2002 08:23 AM
